Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ed5kvexvb07 WHEN I FIRST HOOKED UP THE WATER LINE, IT WORKED FINE. AFTER 2 DAYS ,THE WATER STOPED COMING OUT OF THE DESPENCER.ICE MAKER IS WORKING FINE.
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
SOURCE: My whirlpool refride #GD5RHAXNQOO is not releasing water to the ice maker fill line
Hi all rootbeergirl here. I had the optics changed and the moter on the other side of the icemaker changed I was able to send them both back to Whirlpool because they were both faulty and my fridge was still under warranty and the repair person I had out was a whirlpool warranty certifed rep. I guess I was lucky but whirlpool did tell me that they were having issues with both parts burning out. But now that they are changed it has been been working like a charm. The repair man did suggest that if you are not useing your ice maker alot then you should turn it to the off posistion and let the ice run low or dump the ice holder on a weekly basis. Hope this helps. alsop to replace both parts if you have to pay runs about $300.00
Posted on Oct 06, 2008
  • 358 Answers
SOURCE: ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Posted on Apr 07, 2009
lester482529
  • 226 Answers
SOURCE: Need to replace the ice maker part # 2198597. I need the instruction manual. If anyone can email to me that would be great mdelahan@comcast.net
there may be a seperate pump for the ice maker in the back at the bottom .itmay be cloged due to calcium or other debries check there first.as far as the ice maker,usally it just takes a few screws or a 1/4 in.socket to remove and then a unplug the connection. that motor may need to be checked as well.hope this helps
Posted on May 28, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water coming from in-door dispenser
chances are you have a bad water valve,or the line for water is severed.....the valve your water line hooks 2 has 2 seperate solenoids,one for ice,one for water....the part is sold as an assembly
Mar 03, 2010 | Refrigerators
Ice maker stoped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kgljlgkqerqer
Jan 22, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stoped
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water from despenser but not to the ice maker
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it doesn't
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 22, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Same problem ice maker stoped working model#106.5360202
Yea then check for ice in the water lines, if no jump the water valve direct if you get water then its the ice maker...
Jun 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
May 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ge ice maker stoped working
Check out the tray heating element that is designed to melt the ice slightly so it can be scooped out into the waiting tray.
If there is no water or ice in the tray, then check out the solenoid that allows water into the system.
Apr 19, 2017 | GE LightTouch GSC23LSRSS Side by Side...
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
