Change a light bulb in a visual field machine
Humphrey Field Analyzer
PA8558
  • 28 Answers
SOURCE: Calculated field in Excel pivot
Count will only work with numbers. So select another box where you want your number and use this formula: =count(x:x) This should give the count number then you will need to find the difference. In another box, use =sum(x-x). This should give you your difference.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
SOURCE: using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Posted on Sep 29, 2008
  • 61 Answers
SOURCE: futaba field force 7 instruction manual
Should be here:
http://www.futaba-rc.com/manuals/index.html
Posted on Mar 23, 2009
SOURCE: Field plus key
Use the function Fn key and the + key (which is the colon semicolon key )
Posted on May 22, 2009
SOURCE: can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Posted on Sep 15, 2009
Why no blind spot dectected
The two most common problems when trying to find a blind spot are: A.) Forgetting to patch the eye, and B.) Choosing the correct eye in the machine itself.
Dec 03, 2015 | Zeiss Humphrey 740 Visual Field Analyzer
How do I hook my external laser printer to my humphrey 740?
In the user manual they list some compatible printers that have a 25 pin parallel connector. We use Lexmark Optra E312L with good results. Once you hook it up, you have to go into one of the setup menus to port it over. The user guide tells the procedure.
Oct 08, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How do I fix the pointer on the touchscreen to be where you touch
You sjould press the patient button and the same time turn it the instrument on keep in button press until you see in tje display the calibration message of the touchscreen
Oct 03, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
Sep 18, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How can I fix my screen ,will not show anything on the field analyzer 740i? Help please
Did you move the brighness control. It is on the right side of the equipment. If not, it could be the video board inside of the equipment
Aug 05, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
May 24, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
