How do I make a psuedocode for this problem?! Please Help!
Design a class named Car that has the following fields: 1.Year 2.Make 3.Speed In addition the class should have the following constructor and other methods: CONSTRUCTOR: the constructor should accept the cars year model and make arguments. These values should be assigned to the objects yearmodel and make fielsds. the constructor should also assign 0 to the speed field. ACCESSORS:Design appropriate accessor methods toget the values stored in an objects yearmodel,make,and speed fields. accelorate: The accelerae method should add 5 to the speed field each time it is called. brake: the brake method should subtract 5 from the speed field each time it is called ***Design a program that creates a car object , and then calls the accelerate method five times. After each call to the accelerate method, get the current speed of the car and display it. Then call the brake method five times . After each call to the brake method, get the current speed of the car and display it.
SOURCE: ERROR: Error: Error calling method on NPObject!
Resolved.
Posted on Aug 05, 2009
  • 10406 Answers
SOURCE: Create a class called employee
Nice try!
Find an upper-class student that can give one-on-one tutoring with your homework.
Posted on Dec 02, 2009
  • 121 Answers
you need to do a restore from the tomtom home software on your computer
Posted on Dec 04, 2009
SOURCE: can I get the asswer for the below questions
A book shop maintains the inventory of books that are being sold at the shop. The list has details like author, title, price, publisher and stock position. Whenever a customer wants a book, the sales person inputs the title and author and the system searches the list and displays a suitable message if it is not available. If it is available, the system displays the book details and requests for the number of copies required. If the copies are available, the total cost of the copies requested is displayed, otherwise the message ‘copies not in stock’ is displayed.
Design a system using a class called BOOKS with suitable member functions and constructors. Use new operator in constructors to allocate required memory space.
Posted on May 27, 2010
SOURCE: When I try to operate my Go920:Error calling method on NPObject!
Did you find the solution? I am getting the same with my Go 730
Posted on Dec 11, 2010
What type of SD card is most suitable for recording/playing digital TV programs?
The SD card needs to be a high speed SD card. The speed of the SD cards are classified by Class no. I suggest you use Class 6 SD cards or higher. The higher the speed the higher the cost.
Jun 26, 2010 | Computers & Internet
I dont have a program wifi for net
I love to help you but you have not specified the Computer details is it Laptop or Desktop but the following steps may help you solving the issue
First Check the following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 21, 2010 | Computers & Internet
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
WHAT DO I DO IF A CUSTOMER CAN ACCESS THE WEB BUT CANNOT SEND OR RECEIVE MMS ON HIS KRZR PHONE?
Check the MMS settings...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Port 1: 8080
Domain 1: blank
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press Menu.
Oct 14, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Unable to import text file to access table
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Sep 08, 2009 | Microsoft Access 2003 for PC
No internet connection it is a unlock phone from t mobile to att
Hai, Go into Web Sessions and change the Internet and MMS settings to those appropriate for AT&T. If the T-Mobile settings are locked, create new settings and make them the the default. Each carrier has its own setting but those settings are the same for any phone on that carrier's network.
Browser Settings (in web sessions): ---------------------------------------------------------------------------------------------------- Name: Cingular Wireless Internet
Homepage: http://device:home or http://device.home Service Type 1: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------- MMS Settings (in web sessions):
Homepage: http://mmsc.cingular.com Service Type: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------------------ MMS Settings (in Message Center>>>Message Setup>>>MMS Message Setup): Hide fields: Cc.Bcc.Priority Autosignature: Download: Automatic Filter: Expire After: 5 days Reply Type: MMS Size Limit: None Server Info: Cingular MMS>>>Select Server Info>>>Current Server>>>New: Service Name: Cingular MMS
Server Name: http://mmsc.cingular.com Web Session Name: Cingular MMS.
Some settings may not have to be entered for all phones because they are set at the default for those models. You can leave the User Name and Password fields blank.
Aug 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I WANT TO CREATE A DATABASE FOR PDF FILES USING MICROSOFT ACCESS
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Mar 24, 2009 | Microsoft Access 2003 for PC
Need network setting for AT&T for new CECT A380i
Go into wap settings in your phone and add new connection and use these settings.
Service Type 1: WAP
Port 1: 9201
Service Type 2: WAP
Port 2: 8080
Timeout: 5 minutes
Speed (Bps) 1: 9600
Line Type 1: ISDN
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
Mar 16, 2009 | Cell Phones
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
Oct 22, 2008 | Microsoft Access 2002 for PC
Restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Oct 03, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
David Payne
David Payne
