I cannot remove Panasonic TH-42PD60B from the stand.
I removed the two securing bolts but it won't come off.
SOURCE: removing the stand from tv
I called Panasonic customer service and they directed me to their website where I was able to download that portion of the manual that addressed removing the stand.
Posted on Feb 04, 2009
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
SOURCE: Panasonic Viera TH-37PX70 Pedestal Stand
i need the instrucation how to install the pedestal stand
Posted on Mar 10, 2009
  • 92 Answers
SOURCE: removal of tv stand
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
Posted on Sep 07, 2009
SOURCE: I am trying to remove a stand ty-st42px5w. I have
Did you have any success with the stand? if so .. if you haven't already sold it are you considering selling it?
Posted on Mar 12, 2010
How do I remove tv from stand Panasonic th-37pe30 tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 28, 2014 | Panasonic TH-37PE30 37 in. Plasma...
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
How to remove the seat of 1999 v star 1100
Hello
1)Engage the kickstand and ensure the Yamaha is securely standing. Examine the front part of the seat, closest to the speedometer. You'll find a bolt.
2)Remove the front bolt with a 10-mm socket wrench. This unhooks the front part of the seat assembly. Move to the rear part of the seat.
3)Examine the rear part of the seat to find the 5-mm Allen bolt. Remove it with the Allen wrench.
4)Grasp each side of the seat and simultaneously lift it upward and backward to remove it from the Yamaha 1100.
I hope it helps. Don't forget to rate.
Thanks
Aug 29, 2011 | 2000 Yamaha V Star 1100 Classic
I had the tv on the wall ,and now i wont to put it on the stand, but i have miss placed both sets of screws/bolts, 4 connect the stand base to the back of the tv and another 4 secure the fill in on the...
It should be M6 bolts.
Simple thing would be to go to Home Depot or Ace and pick up a metric bolt assortment kit. They're usually pretty cheap, and always handy to have around.
Jul 04, 2011 | Televison & Video
How do I remove the starter motor from a 1993 Ford Fairlane?
  • Use a wrench to loosen the bolt and nut assembly that secures the negative battery cable to the battery, then lift the cable away from the battery.
  • 2 Apply the parking brake and raise the front of the car with a jack, then lower the vehicle onto two jack stands. Place one jack stand on each side of the front of the vehicle, under the frame.
  • 3 Access the starter from underneath the passenger's side of the Falcon. The starter is between the engine and the transmission and looks like a large coffee can.
  • 4 Remove the battery cable from the side of the starter. The cable slides over a threaded stud and is secured with a single nut. Remove the nut with a wrench, then lift the cable away from the starter.
  • 5 Remove the two flywheel-to-starter retaining bolts with a wrench, then pull the starter toward the front of the vehicle to remove it.
  • 6 Position the replacement starter against the flywheel housing, then install and tighten the two flywheel-to-starter retaining bolts with a wrench.
  • 7 Slide the battery cable onto the threaded stud on the side of the starter, then install and tighten the retaining nut with a wrench to secure the cable in place.
  • 8 Lift the vehicle with the floor jack, remove the jack stands, and lower the Falcon to the ground.
  • 9 Position the negative battery cable onto the battery terminal, then tighten the cable into place with a wrench.
  • Apr 28, 2011 | Ford Fairmont Cars & Trucks
    How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
    Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
    Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
    Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
    Feb 10, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
    Removal of tv stand
    Sep 06, 2009 | Panasonic TH37PX60 37 in. Plasma...
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
