Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Lamp light flashes
Lamp light flases, fans run set does not come on. Replaced lamp, same problem.
  • bigmoe63 Aug 28, 2007
    anyone know the part number for the color wheel in HLP4663w projection set.
    Sergeant:
    Champion:
  • 375 Answers
Wiil get back to you.
Posted on Sep 12, 2007
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
A new bulb has been replaced. The red power light
Are you SURE that the lamp door switch is properly in place?? This sounds like a problem of this type. If this is Ok, and the lamp does NOT try and strike, check to see if the fans are starting. if they try and start, and then the set shuts down, one of the fans is bad or clogged with dirt. If NOTHING happens but the 3 blink code and the door switch is ok--perhaps the thermal sensor above the lamp has opened, due to excess heat and/or poor ventilation.
Oct 15, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
Htachi Rear Projection Picture/Sound Lost
If you never replaced the lamp it may be time.4 years to run on 1 lamp is a good run.If you were having no other problems I would say it`s safe to say that will solve your problem
Jan 14, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Mitsubishi WD-52725 FAN?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
