Question about Refrigerators
Delfield vrr2s Erratic temperature flucuations can freeze or be to warm?
It comes on a stay cold for about a week then it shuts down, what is the problem? Please help!
Check the defrost heater, sounds like it is burnt out allowing ice to build up therefore restricting cold air flow. Then the freezer warms up, ice melts and it starts freezing again.
Nov 30, 2010 | Delfield Freezer 6151XLSR Stainless steel
We have a Delfield 407 freezer that will freeze when initially plugged in, fan running, gets nicely down to zero. After the unit gets down to temperature, the fan does not kick in again and the unit...
You will need to replace the temperature assembly on the unit. If you can post the model number, I will be able to direct you to the parts you need. The model number will be something like "18648-BUC".
Regards,Richard
Nov 11, 2010 | Delfield Undercounter Freezer - 407
My 99 alero's rpm gauge is flucuating now what is the problem?
YOUR ENGINE IS DOING A THING LIKE ERRATIC IDLING.THE POSSIBLE CAUSE CAN BE MANY THINGS LIKE LOOSE BOLTS ON THROTTLE BODY OR INTAKE.LEAKING VACUUM HOSES.DIRTY FUEL INJECTORS.BAD PLUGS AND WIRES.ALSO DIRTY THROTTLE PLATE WITH CARBON BUILD UP ON THE THROTTLE BODY. CAUSE ROUGH OR ERRATIC IDLING.
Oct 13, 2009 | 1999 Oldsmobile Alero
How do I adjust the defrost system?
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
this is the site with a manual for the 6151S unit.
http://www.delfield.com/docs/uploaded/del/manuals/DM6000XL.pdf
here is another manual for the XL-S unit.
Hope this gets you what you are looking for
Jul 30, 2009 | Delfield Freezer 6151XLSR Stainless steel
1999 Dodge Caravan Air Conditioning flucuating
Sounds like system is low on refrigerant and needs to be checked for leaks - could be anywhere on one of these.
Jun 26, 2009 | 1999 Dodge Caravan
Delfield 4048-12 freezing up!`
Yes, it could be the thermostat. Here are all of the reasons that could be causing your problem Read through them as a guide on how to proceed. Get back if I can help you further.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
May 21, 2009 | Delfield 4464N-12 Commercial Refrigerator
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
