How to print with heavy card stock on Toshiba e-studio 6540c
  • 24 Answers
SOURCE: Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Posted on Sep 24, 2007
Jay_Sav
  • 93 Answers
SOURCE: can not get the card to feed the printer
This printer isn't designed to take heavy paper, only office standard, and slightly heavier for smarter documents / photos. Best idea would be to print one on smart bright white paper (or desired colour), and take it to a copy shop where they can print onto card. The problem is that the thin paper will easily roll round the rollers at the back, however the thicker paper can't, and therefore jams with the rollers tickling the end of it.
Good luck, and congrats on wedding :)
Posted on Mar 14, 2009
  • 220 Answers
SOURCE: Jamming when Print heavy paper on Samsung 510
printer only handles up to 120gsm,any thicker will jam.
Posted on Jul 15, 2009
  • 105 Answers
SOURCE: Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Posted on Oct 17, 2009
  • 82 Answers
SOURCE: I AM TRYING TO PRINT HEAVY STOCK CHRISTMAS CARDS -
If its heavier than 60 to 105 gsm (16 to 28 lb), then your printer can not take that type.
HP Specifications
Unless there is a manual feed on the back, the paper won't be able to bend well inside of the printer, hence the jam.
Posted on Nov 29, 2009
Toshiba 6540c error code F900 how to solve
F900 is Model Information Error
Perform SRAM-Re-Initialize Support
If cannot, perform Key FROM to SRAM
Mar 15, 2017 | Toshiba Office Equipment & Supplies
It wont print on heavy paper
You may have to use the manual feed tray on the side of the copier. It is not designed to run through the paper tray, to many bends....Good Luck
Mar 08, 2013 | Toshiba e-studio 203sd
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
I have Toshiba photocopier, Studio 455. i want to print one page label paper. Should i use a bypass, which i tried but did not work. Tell me how.
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
Sep 14, 2010 | Toshiba e-studio 455 Copier
HP Specifications
Nov 29, 2009 | HP Office Equipment & Supplies
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Toshiba e-Studio120 no printing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Toshiba e-STUDIO 120 Laser Printer
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Ink smudges when printing cards
If you are using cardstock you have to tell machine that you are using thick paper. Place cardstock in bypass select paper size then select thick 2 or thick 3 as paper type.
This increases trasfer charge ,increases fusing temperature ensuring image is bonded to card stock paper.
No more smudging
Jan 12, 2008 | Toshiba e-Studio 232 Black and White...
Heavy weight paper
Hi it would appear that the paper is too heavy for the machine check the manual as it will have the spec on what paper can be used and also how heavy the paper could be.
Sorry I cannot be anymore help but try using a paper that is about 10-20 gsm lighter.
Thanks J
Jan 11, 2008 | HP DeskJet 1220c InkJet Printer
119 people viewed this question
jasbo
jasbo
