Hisense codes The indoor unit shows ER or EA blinking all the time. When the AC is ON no temperature is shown but instead ER or EA even when it's off. How to get it back normal. thank you
bobotfel
  • 236 Answers
SOURCE: blinking indicate at indoor unit
reset your unit by disconnecting the power supply for 10sec. and "on " the unit for testing. if error persist you need to replace your thermistor.
Posted on Jan 26, 2009
  • 21 Answers
SOURCE: model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
Posted on Aug 06, 2009
SOURCE: indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Posted on Apr 09, 2010
  • 4 Answers
SOURCE: The indoor unit fan of the split ac runs all the
Is there a auto/on switch for the fan? In auto it will only run when the condensing (outside unit) runs. If its in the on position it will run all the time. Also, possible bad thermostat stuck in on position. Check and see if the condenser unit is also running all the time.
Posted on Jul 21, 2010
ginko
  • 19396 Answers
SOURCE: Have a Multi Split Indoor unit ASU9RD - 2 units
Hi.
Here error codes:ERROR CONTENTS
Here a complete service manual.
Here user manual.
Before doing anything else, power down the main circuit breaker, so to power down each unit and reset the electronics in the whole system. If all units have gone down at the same time, this will often solve the problem.
Regards.
Ginko.
Posted on Feb 15, 2011
My hiatchi logicool ac indoor unit red led is flashing, I am not able to switch on either from remote or indoor unit.how to get rid of of the problem
Chances are pretty good that it is a safety lock out. Generally, the light will either constantly blink or blink a numeric code to help to diagnose the cause of the lock out. You can try to re-cycle power to the equipment, but if that doesn't clear the code and allow the system to restart, then it is time to call a repairman.
Jul 25, 2016 | Heating & Cooling
MY AC SAYS EA ERROR .WHAT IS WRONG WITH MY AC
global.hisense.com/cuse/.../airc/.../P020100111395003864449.p...
global.hisense.com
hisense.uz/en
Sep 09, 2014 | Cars & Trucks
Haier air conditioner won't run displaying code e1? Do not have remote.
This is the error code.
E1 = Room temperature sensor fault Indoor unit
Even if u had the remote you still have a bad sensor.
AC Repair Delray Beach
Sep 03, 2014 | Haier Heating & Cooling
Hitachi indoor unit showing red light blinking in nine times
relay must be change,
or the indoor unit board to be change
Jul 05, 2012 | Heating & Cooling
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
May 12, 2010 | Hitachi RAS-09UH Air Conditioner
Blinking indicate at indoor unit
Jan 25, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
