Question about Watches
How do I reset my Ridgeline Denali field watch?
Reset timex t49905 circuit board
I recommend getting it to watches repair shop
but if u insist remove the battery and but it back
May 15, 2014 | Timex Watches Field - T49905
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
2 hours back?
Severe shocks,drops or strong magnetic fields have as result the wrong indication of watch hands.Try to reset your watch by the hands "0 set" procedure following manual instructions.
Mar 18, 2013 | Casio Watch Edifice Eqs-500c-1a1er Man...
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
How do I zero the stop watch
Pull the winder out to either the 1st or 2nd click & use the push buttons to zero the hands in.
Jul 19, 2010 | Luminox Field 821 wristwatch
Wenger field chronograph only works when not in use
Take or send it back to your supplier, with an explanation of the problem.
Feb 06, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Cl 5008 Can't set time. holding down set button gets to an offset option.
Try resetting your watch first. To do that press all four buttons at the same time.
Then to set the time, hold down the set button until the display flashes. You can then use the mode button to cycle through the display features and set them. Use the strt/stp and reset to adjust fields.
Oct 16, 2009 | Columbia All Sport Digital watch
Calibre S affected by magnetic field
All watches are affected by magnetic fields.
Yes, your Tag watch will be affected. If it has been in a magnetic field it will need to be serviced to remove the magnetization from the movement parts.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Tag Heuer Link WJF2112.BA0570 Wrist Watch
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
Watches Logo
330 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
