Panasonic air conditioner with seral nr. A75C2616
The timer light is blinking and the air conditioner do not work at all
    New Friend:
  • 14 Answers
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Posted on Jul 15, 2013
  • I have found out that problem with the air conditioner, I turn off all electric in tje living room and then it started but thanks for your help and i nice day
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Mitsubishi Air Conditioner blinking Problem
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
hvac1960
  • 2133 Answers
SOURCE: panasonic air conditioner CS-E24GKR...The unit
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Posted on Jan 03, 2011
shastalaker7
  • 1515 Answers
SOURCE: My panasonic cu-e24ekr air conditioner
Hello, I have looked up this unit with no feedback on the meaning of what your codes stand for on Panasonic models like yours. The operations and trouble shooting manual is no longer available to download anymore as I was told. I can have you try to remove any batteries from the remote to see if this will rest this unit. If so, great. If not, I will continue my search to help you solve your problem at this time, and get back to you.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jan 07, 2011
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
521 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
