LG netbook When i press the on button, The green light comes on and i hear the fan spinning but the netbook does not boot up and when i press the power button and hold it down, the light does not go off.
    Problem Solver:
  • 7 Answers
This could be trigered by Low voltage in the CMOS battery, normally the CMOS battery voltage is 3V and therefore if it is lower than that, lets say 2.8V, you should consider repalcing it but first have a look at it.
You should also ensure that the power supply is adequate.
Check the connectors for any pins that may be bent and make sure they have been straightened and be very cautious, they might break.
Jumpers may come off when the notebook is moved, so you should check if they are fitted properly.
Try all this and if not successful, then consider returning it to the store for check up.
Posted on Jul 15, 2013
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
SOURCE: power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Posted on Dec 04, 2007
  • 95 Answers
SOURCE: Toshibas are dieing on me.
How about if you boot with just the battery in? Does the battery charge? Possible solution include: remove and replace memory chips to make sure they are seated correctly. Check with a known good power supply. Almost sounds like a motherboard issue to me. Plenty of laptop problems are related to bad solder joints on the motherboard, unless you or someone you know can open it up and find a bad joint the only solution is mother board replacement. Try reseating the memory first.
Posted on Dec 08, 2007
SOURCE: no power up
Here was the fix for me. The machine refuses to boot if the video card is not functioning. It should have one long beep however to tell you that there is a video problem. Someone hooked up our speaker incorrectly though! So we got no beeps. Once the speaker was hooked up and the video card was replaced, all is well!
Posted on Jan 02, 2008
  • 2427 Answers
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
All lights are green except the third light is red.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Netbook won't turn on when plugged in
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell Inspiron Mini 10v Netbook Computer
Can't turn on my mini netbook inspirion - help
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
Laptop doesnt boot only power ligth comes out when press on buttom a ligth comes out but nothing on the screen i dont hear the fan keep going.
Maybe there are some problem in your start button (the button wire connect to mainboard is Loosening.
Please press the start button for about 3-4 seconds then see it would start. Always it may solve the problem, this happend to my inspiron 6400 too, after used for years the start button failure. It shows only power lamp lights green but the other light cant light red.
If no, maybe your must change a power supply, as the lower volt current cant start all the device.
May 15, 2009 | Dell Inspiron 6400 Notebook
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
