Question about Spectrum Technical Hifi EQ-B5100 Professional Equalizer with (Black) Home Equalizer
Equalizer hook up.
I will getting an equalizer soon and have read to hook it up to the tape deck outouts on my receiver. Is this correct? Also, does the tape deck then hook up to the back of the eq? Kevin
  • jabo Dec 18, 2007
    I have a dbx 1215 eq. The rca jacks on the denon 697ci reciever and the jacks on the dbx eq are not alike. I wasn' sure about the dbx connecting to a home stereo unit but it kept showing up on the web site as compatable with home units. will it work. jerry from tennessee
    Problem Solver:
  • 4 Answers
Only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Posted on Nov 03, 2007
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
How do I hook up an equalizer to my Yamaha RX-V630 Receiver ?
you hook it up through your tape monator just like you were hooking a tape deck up if you have a tape deck pluged in there you should be able to plug it in to the back of equalizer the same way
Sep 08, 2014 | Yamaha RX-V630 Receiver
How to conect a equalizer sh-ge70 to a receiver hdmi
Any equalizer I have seen can be hooked to the tape loop of a receiver and then any tape deck displaced from that loop if one was plugged in will be hooked to the tape loo[p on the equalizer.
This is a very simple process and one that is often given in the owners manual of the equalizer involved.
Sep 25, 2013 | JVC TD-W118 Single Cassette Deck
Need manual
Ron there is no such manual except those that might come with the Equalizer- Actually , the process is very simple. You take the output of the equalizer in hook to tape in. Tale the record out of the tape loop and hook to input of the equalizer. Then the equalizer will work when the tape look (tape monitor) for the receiver is selected- that is why it is called a tape loop as signal goes out and comes back in. If you have Pre outs and Pre in you could use it there too. In the tape loop connection any tape deck is then hooked to the Equalizer tape inputs- some have two.
Dec 31, 2012 | Audio Players & Recorders
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
HOW can i connect this ross model eq r15s to my avr687 denon rece
Treat each EQ (or any processor) as as Tape Deck and place it on its own Tape loop on the Denon. Tape deck(s) can attach to external processors because they always have tape loops to replace the one they use.
Rule of Thumb: OUT's go to IN's.
You can have as many processors as you want. I have five.
You can serialize processors if they would logically be used together or you could get a dbx-200 or dbx-400 Program Route Selector which provides connections and switching facilities for 3 processors and 3 tape decks but uses only one tape loop on the receiver.
Individual processors can be engaged or disabled, and the whole mess can be placed in the record OR the playback end of the chain - all via front panel switches. Very versatile.
Apr 21, 2010 | Audio Players & Recorders
I have a teac receiver AG-790 and would like to hook an equalizer to it. How do i go about it?
Find the manual at:
http://www.teac.com/consumer_electronics/receivers_&_tuners/ag-790a/
and on page 6 they show how a Tape Deck is attached. Attach the EQ exactly like that and if you have a Tape Deck or two attach IT(them) to the EQ as if IT was the receiver.
To engage the EQ at the receiver choose Tape and everything passing through the receiver wil lbe routed OUT to the EQ and back IN via the PLAY connections.
Apr 10, 2010 | Teac EQA-120 Home Equalizer
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Sep 17, 2008 | Gemini Sound Products EQ-300 Home...
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
1,160 people viewed this question
Top Spectrum Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spectrum Audio Player and Recorder Expert? Answer questions, earn points and help others
