Question about Garden
Husqvarna royal 48 carburetor - Garden
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do i replace pull cord on husqvana royal 48
There is a video on youtube explaining the full procedure.
Mar 14, 2012 | Husqvarna Garden
I have to pour gas in the carburetor to get it to start. What do I need to fix it?
The jets in the carb are blocked, disassemble and give a really good cleaning of all hole and passages. Remember to take a picture of the linkage attachment to the carburetor or take good notes.
I hope this helps.
Aug 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My starter will turn the engine however, it will not fire. already replaced fuel filter, air filter, plugs and battery. any suggestions. prior to this happening the mower would start and run then the...
Do you have a fuel shut off solenoid on the carburetor? If you do there will two wires going to a solenoid on the bottom/bowl of the carburetor. You need to make sure this is working properly. You may also have some debris or blockage in the main metering jet in the carburetor. Hope this offers some type of help.
Feb 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My Husqvarna will only stay running with the choke in and even then it will only run for a short time?
Gas flow through the carburetor is clogged. Easy fix is the following----- remove all gas from tank (siphon or drain). Put that gas aside or dispose of it. Use a little bit of fresh gas and a little bit of carburetor cleaner in the tank. Run that through (by running the motor with the choke.). Do it several time if needed. When it seems to be running better, then try just a little gas only to be sure you have cleared it. When you fill-er-up, be sure to add a gas additive like Sea Foam or similar.
Apr 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna TYH 2248
If it stalls when you let the clutch it can be a problem with carburetor settings.
If idle is too low the engine will shut down when you leave the clutch pedal.
Set carburetor and see how it goes.
Sep 14, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
