Question about Windchaser Outdoor Misting Fan WC161 Stand (Pedestal)
Parts the part that connects fan to stand needs replaced
What is an 800 telephone # to customer service? I need replacement parts and wish to talk to a person.
First of all, why would you buy a fan with missing parts? Second, why would anyone give you the parts for free? And lastly, You haven't told us what make/model fan you have. fanman9952@aol.com
Aug 12, 2014 | Dryers
HI,,our asimo stand fan FL-16RD with remote control,is not working and making some noise if we turn it on
Pls help locate ASIMO electric fan service center in Manila. I need control board parts.
Thanks and brgds.
Apr 11, 2013 | Holmes Products Dryers
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Where can I get a part for my Windchaser 16" osilating stand fan, model IVS182. It stopped osilating and needs the small part that helps it osilate. Don't know what it is called.
Check with the manufacturer, they should be able to get you the replacement part. Maybe they show a diagram online with names of parts that can help you name it, so they can send you one.
Hope this helps. Good luck!
Jul 30, 2009 | Windchaser (IVS182A) Stand (Pedestal) Fan
Broken bracket on lasko pedestal fan
I have the same problem. Called Lasko parts department and got one. http://www.laskoproducts.com/
Description of part on invoice - 05098021T BAG HDWR BASE T/BLK 30PTEXTURE BAG
Cost $7.50 for part plus shipping to me was at $6.61 so it was pretty cheap. Comes as a package with four screws/washers/nuts. Hope this help someone out there.
Sep 08, 2007 | Lasko 3135 Stand (Pedestal) Fan
Windchaser Outdoor Misting Fan WC161 Stand (Pedestal) Logo
22 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
