Dx32e250a12 i connected hdmi cable from computer to tv. what channel do i use to view?
    Top Expert:
  • 12,223 Answers
You must follow the instruction from your use manual or download
from www.retrevo.com
God bless you
Posted on Jul 15, 2013
Hdmi cable for 40" led TV WHAT ARE THEY FOR
The hdmi cable is used to connect the tv to devices so it can be displayed on the tv. Devices such as, but are not limited to, computers, bluray/DVD players, gaming consoles, etc...
For channels, you have two options.
1. You would need to purchase a cable package from one of the options in your area. They will run a line I to your house and provide you with a cable box in which you connect the cable box to the tv via hdmi cable.
2. You can purchase an antenna and plug it into the tv. Run the channel search and you'll have those channels. Some TVs may have built in antennas but if yours doesn't, I'd go for a simple antenna from target or best buy. Or you can purchase it online.
Thanks!
Sep 22, 2014 | SEIKI Digital SE40FY19 40" LED TV...
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Aug 23, 2014 | Acer Aspire 5350 5750 5750g 5750z Series...
I wanna change my wireless. Camera to be able to connect to my tv
Assuming you can view your wireless camera on you computer and that your computer and TV have HDMI ports, connect an HDMI cable between computer and TV, Then set your TV to get it's input from HDMI and your camera should display on the TV.
Feb 08, 2014 | Computers & Internet
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Jan 27, 2007 | Arris DCT6200 DTV Receiver
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
