Question about HP C5957A Color LaserJet CM8050 MFP Printer, Refurbished
ERROR CODE HP CM 8050 MFP SHOWING ERROR CODE D1.073B WHAT COULD BE A PROBLEM
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
YourZEN
  • 820 Answers
SOURCE: how do I install a hp laserjet cm 1312nfi MFP
There's Windows 7 support for the CM1312 series, see next site:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=3562006&taskId=135&prodTypeId=18972&prodSeriesId=3558902&lang=en&cc=uk
Pay attention to downloading and installing the matching bit-version (32 or 64) for your system.
Posted on Nov 03, 2009
SOURCE: scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Posted on Jan 14, 2010
  • 3 Answers
SOURCE: error message on display of hp m 1005 mfp
HELLO
Posted on Jun 03, 2010
  • 96 Answers
SOURCE: Have a HP Photosmart 8050. Won't Print. In the
go on web site www.hp.com they will answer your question after putting in you model number of the printer you have
Posted on Jul 27, 2010
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
I have a printer hp CM8050 Color MFP showing error code D1.073B what is the problem
This was a problem previously answered here:
http://www.fixya.com/support/t18887496-hp_cm_8050_printer_showing_error_code
May 24, 2014 | HP Office Equipment & Supplies
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
I have hp cm 8050 printer showing error code D1.073B
follow this steps and fix it. God bless you
Instructions
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2Z7d9rxWS
Jul 15, 2013 | Office Equipment & Supplies
Hp laserjet pro cm1415 fnw color mfp 51.23 error turn off then turn on
Aug 24, 2012 | HP Office Equipment & Supplies
Hp lasrjet cm1017 error 5021
50.21 error is a "cyan scanning error"
Manual says to replace the DC Controller.
Get a tech to check it out, and if you want to get the printer printing again, listen to him.
Jul 30, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
Jul 27, 2010 | HP Photosmart 8050 InkJet Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
HP C5957A Color LaserJet CM8050 MFP Printer, Refurbished Logo
54 people viewed this question
Seeker5211
Seeker5211
