Question about Sharp AR-5316 Advanced Digital Imager Copier
Error code MY COPY IS SHOWING ME H AND 5
U2-40
Posted on Jul 29, 2013
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Nov 07, 2014 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Error code E7
It would be helpful to know the error sub code. With the error showing press and hold your start/copy key, this will provide the sub code.
Thanks
Follow me on Twitter @CDOS_Service
Jan 09, 2014 | Sharp AR-M205 Copier
My Sharp AR275 is showing wrror code f5-02 please what will i do?
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Feb 26, 2013 | Office Equipment & Supplies
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
oolmii@yahoo.com
Aug 12, 2012 | Toshiba Estudio 200L Copier
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Error mesege Showing E1
The E codes E1-E7 are displayed in the copy counter.To display both digits of the E code press the ENTER key.When the machine detect E13 condition E1 is displayed in the copy counter.Hold down the enter key and 13 is displayed.
E 11 - Exposure lamp error.In this case check the exposure lamp continuity,the thermofuse is open or power suplly board defective.
E 12 -Exposure lamp error .AC drive defective,main board defective
E 13 - Zero cross signal error.Main control or DC power board defective.
To clear the service code turn OFF/ON the machine.
Sep 09, 2009 | Ricoh Office Equipment & Supplies
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
