Question about Sylvania Wireless Smartbook - SYNET07WICV
Hours of Use
Before investing in a New battery, On average how many hours Portable use can a user get out of a Fully Charged Smartbook?:
2 Suggested Answers
matic_lahajn
  • 7 Answers
SOURCE: Portable Battery Time
Probably around 4-6 hours, depends on how much you use it and the setting about power save.
Posted on Jul 16, 2013
Motorhome house batteries were dead because five hold lights were left on. It has been pluged into ac for 24 hours and lights when turned on are quite dim. Do think the batteries have been damaged?
It is possible the batteries were damaged but if they were healthy and not too old, they probably weren't damaged.
The in-house charger will be either an intelligent type or a low current type, both of which would be unsuitable for recharging a completely discharged battery.
The batteries should be removed and independently charged with something more suitable and in the case of a deep discharge it might be necessary to give them an electrical kick to get them started - like starting a 12 volt battery off with a 24 volt charger.
It is important to monitor the current and ensure it doesn't heat the batteries very much as that shortens their life. If the batteries aren't sealed don't be tempted to top up the liquid in the cells as the level will rise as the battery is charged.
Think of charging a battery like filling a tank - the capacity of the tank divided by the fill rate gives an indication of how long the tank will take to fill. A 100 AH battery at an average charge current of 5 amps will take 20 hours to recharge.
Realistically the average charge rate will be much less from the average battery charger and if the battery is no longer young it will take longer for the necessary internal chemical changes to take place so recharging fully is likely to take anything from a couple of days to a week.
It is important to ensure they are fully charged before being put into service again in order to avoid partial sulphation. The best method of checking is with a hydrometer but that is impossible with sealed batteries and a voltmeter provides an alternative. An accurate measurement of battery voltage can only be made when the battery has been off charge for several hours.
Apr 22, 2017 | The Computers & Internet
Jul 16, 2013 | Sylvania Synet7wic-bk-z2 Netbook
My smartbook will not charge. I plugged it in and have charged it 12 hours. No lights comes on neither does the smartbook.
More than likely your power supply is dead, you may need to order a new one. You can always take it by Best Buy or a similar store and see if they can attempt to charge it as a test.
Aug 23, 2011 | Computers & Internet
I purchase s10-3 netbook. i had problem with its battery which only runs 2 hours if it is fully charged. please assist!
How long have you been using the netbook? If it's brand new, then your battery life is too short. First of all, remember the following for ensuring that your battery performance is optimal:
1. A new battery pack must be fully charged before it is put into use.
2. A new battery pack needs to be fully charged and discharged a few times before it starts performing at full capacity.
3. Batteries discharge when left unused. If you intend to store the netbook for a while, make sure that the battery is fully charged before you do so.
4. Fully drain and fully recharge your batteries every few months.
If your netbook is new, then try one or more of the following and see how your battery performance gets affected: 1. Turn down the LCD brightness of your portable device.
2. Use built-in power management on your portable device.
3. Turn off LCD or other unnecessary accessories when not in use.
4. Set screen saver blank to 1 to 2 minutes of your netbook.
5.. Add more RAM if you can, as this will reduce the usage of the hard drive which exhausts the power quicker.
Hope this helps.
May 24, 2011 | Lenovo Computers & Internet
Been on charge for 24 hours red light on but still not flashing to say fully charged
The rechargeable battery in your MP3 player needs to be replaced, generally speaking the average life span for a battery is 1 to 3 years.
Mar 19, 2011 | Audio Players & Recorders
How long do batteries take to charge in charger?? does green light mean they are charging?? does light change color or go out when fully charged? I don't have the user booklet and can't remember. I do not...
Some lights go out once charged...most chargers are with protect circuits so once the battery is fully charged the charger will either switch off or go into trickle mode...So e new battery manufacturers insist on 12-16 hours charge before first use....some batteries are already charged...you should check with a battery checker...but usually those that are precharged cost almost twice as the ones that are not.
Nov 11, 2017 | Ray-O-Vac Cameras
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Feb 07, 2009 | Sony Ericsson W910i Cellular Phone
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Samsung e900 - battery life
replace the mobile phone charer and then try
Sep 07, 2007 | Samsung SGH-E900 Cellular Phone
Sylvania Wireless Smartbook - SYNET07WICV Logo
21 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
