Question about Bryant Legacy 16 Series 4.0 ton AC Condenser R-410A
Where can I obtain a se4rvice manual for a bryant Model:113ana024-d
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Bryant 398AAZ MANUAL
Link below for the Bryant 398AAZ manual.
Bryant 398AAZ Manual
Nov 25, 2013 | Heating & Cooling
Bryant model 394GAD manual
The manual can be downloaded here: http://www.bobsmanuals.com/Household/Heating_and_Air_Conditioner/Bryant/394GAD/manual/
Jan 09, 2012 | Heating & Cooling
Manual bryant model 394GAD
Here's a link to the manual, as requested.
Bryant 394GAD Manual
Manual for model no. 234c 5pw bryant boiler
I have a bryant boiler in my home and been having a plumbing co work on it since spring and they replaced the 3 speed pump with a single speed now cant get it to push air out of system
Nov 08, 2010 | Bryant Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Bryant outdoor model # 567A-018E it humms like
open up it is probably the contractors. and easy fix you can push them down manually but be careful they are HOT- LIVE.if not sure call someone who does!
Jun 26, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant Legacy 16 Series 4.0 ton AC Condenser R-410A Logo
23 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
