Question about agoda.com
Cannot display page - agoda.com
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
Feb 05, 2013 | Microsoft Internet Explorer 7
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
Page can not be displayed
This seems to be a conection problem, check your internet settings, and you connection route. If this is note you problem simply upgrade your Explorer at www.microsoft.com check for the tab updates.
Good luck
Mar 03, 2010 | Microsoft Internet Explorer 6
Cannot display page, link http://www.yahoo.com/r/m2 failes
tried to display another web page no luck...turn off firewall and see if it was blocking web page no luck...
May 02, 2009 | Computers & Internet
Cant display page even though I'm connected
On that "cannot display" page, If it shows click diagnose connections problems". Follow directions.
Apr 29, 2009 | Computers & Internet
2005 mercedes benz 320 diesel
These instructions will work from 09/01/2003 and up 211 Model E Class Mercedes
1. Insert igntion key, switch to position "1"
2. press the page button (looks like a page in front of another page. Use the one with the writing on the rear page) on the steering wheel controls repeatedly until the mileage is displayed within the multifunction display.
3. Press the cluster illumination button 3 times in short succession. The battery voltage will be displayed.
4. Press the up or down arrow buttons until the service menu appears.
5. Use the + and - buttons to select the menu option "confirm"
6. Press the page button on the steering wheel until " complete service" is selected.
7. Confirm "Complete Service" with Page Button. The display will show "Service Confrimed"
Sep 16, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Internet pages not in widescreen
display resolution incorrect go to display settings and resize the screen until it is wide as the monitor, 5 inches thats allot of blank space...
Apr 30, 2008 | Computers & Internet
agoda.com Logo
15 people viewed this question
Top agoda.com Computers & Internet Experts
David Payne
David Payne
Are you an agoda.com Computer and Internet Expert? Answer questions, earn points and help others
