I have hp cm 8050 printer showing error code D1.073B
HP CM 8050 COLOR MFP SHOWING ERROR CODE D1.073B HOW DO I CLEAR THE SAME ERROR AND HELP ME WITH ERROR CODES FOR THE SAME MACHINE.
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
Instructions
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2Z7d9rxWS
Posted on Jul 15, 2013
Testimonial: "Black ink is empty can that bring that problem"
  • 40 Answers
SOURCE: Fax sending problem - error code 81
Greetings John,
This error is for 81 Z no user profile for pre-process.81 error indicates that a temporary error has occured while testing. If cycling the power does not solve the problem you should replace the formatter board.
Also It could be a problem with the power supply or DC controller. There may fluctuating power issues with the formatter. Also did you replace the network card after replacing the formatter or did you use the same network card that was replaced before the formatter was replaced. It may be the new network card may have been damaged by the old formatter and gives the same problem now, and using the damaged network card may have messed up the formatter again. To test this replace both formatter and network card together.
Regards,
TechSup1
Posted on May 01, 2009
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M2727nf Mfp Printer: error code 10.03.232...
An error code of 10 is a print cartridge problem.
Posted on May 27, 2010
puertobori
  • 7733 Answers
SOURCE: I have a hp color
TRY HP Support & Drivers
Posted on Oct 23, 2010
seeker5211
  • 1089 Answers
SOURCE: What is the part number
Part number for the fuser is ...Q3931-67914
Posted on Dec 10, 2010
rathoddipak9
SOURCE: hp color laserjet cm1017 mfp
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Posted on Oct 15, 2012
I have a printer hp CM8050 Color MFP showing error code D1.073B what is the problem
This was a problem previously answered here:
http://www.fixya.com/support/t18887496-hp_cm_8050_printer_showing_error_code
May 24, 2014 | HP Office Equipment & Supplies
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
Hp laserjet pro cm1415 fnw color mfp 51.23 error turn off then turn on
Aug 24, 2012 | HP Office Equipment & Supplies
Hp lasrjet cm1017 error 5021
50.21 error is a "cyan scanning error"
Manual says to replace the DC Controller.
Get a tech to check it out, and if you want to get the printer printing again, listen to him.
Jul 30, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
My hp colourjet 1312 mfp shows me paper jam afetre booting what do I do?
Remove every scrap of paper in the paper path through the printer
Jul 11, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
287 people viewed this question
k24674
