Question about Ambient Weather WS-2090 Wireless Home Weather
My outdoor tempature is stuck on 45.5. What should i do?
Recently purchased clock with tempature and humidity dials, humidistat not working It is outdoors in southwest Florida and it says the humidity is 50 %,no warranty or instructions
what makes you think that the humidity is not correct
it is a indicator that will not move much so don't expect it to move around like a temp gauge or barometer
May 15, 2017 | Humidifiers
Tempature is not accurate
how much is it off? What are you comparing it to?
Feb 22, 2013 | Springfield 91572 decorative...
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
Out door tempature and humidity readings won't display on indoor unit
when mine does that it needs a new battery. hope this helps you
Sep 18, 2009 | La Crosse Sport & Outdoor - Others
Outdoor unit will not run
Some air conditioners have a thermostat that will not allow the compressor to run below a certain out side tempature as it will cause liquit to come back into the compressor(called slugging) and damage or destroy it.
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Dec 14, 2008 | Hitachi RAS-09UH Air Conditioner
NO HEAT BLOWS OUT WHEN I TURN MY HEAT ON
Is the car tempature gauge working ? Another words is the car operating at tempature? it could be just that your thermostat is stuck open and probably needs replaced
Dec 05, 2008 | 2004 Chevrolet Monte Carlo
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Ambient Weather WS-2090 Wireless Home Weather Logo
41 people viewed this question
Top Ambient Weather Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Ambient Weather Measuring Tool and Sensor Expert? Answer questions, earn points and help others
