Question about AM Auto Parts 2006 VW Touareg Mass Air Flow Meter Sensor for Models with V8-4163c
Temperature Coulant Sensor
Where is the temperature coulant sensor located on this car?
    Problem Solver:
  • 7 Answers
Under hood, driver side, upper engine area, mounted in end of cylinder head
Posted on Jul 17, 2013
My Eden pure model Gen 3 doesn't turn on ? The red light on front is lite and filter is clean Why not
Edenpure has a troubleshooting guide at this website: MY HEATER WILL NOT TURN ON.
  • Make sure the power source is good. Plug in a lamp to see if it works correctly.
  • Make sure the front power switch/button is set to the "ON" position.
  • Unplug the power for 30 minutes. Plug the power back in and try operating the heater again. This will reset the internal sensors.
  • Some heater models are designed to be operated in temperatures less than 75 degrees Fahrenheit. The heater will not operate when the temperature is too high. Test the heater in a room that is below 75 degrees Fahrenheit.
  • Bring the heater inside to warm up for at least one hour before operating if it has been stored in a freezing or near freezing environment.
  • Make sure the filter is clean.
  • Remember, it will take a few minutes for the heater to warm up. The fan will start to blow after the heater has warmed up.
Heaters FAQ
Dec 07, 2016 | Air Purifiers
My fan doesn't turn off after I turn the car off its a 93 Oldsmobile Kutless Ciara
There should be a temp sensor for the fan inline with the fuse block. Sounds like the sensor is reading improperly and needs to be replaced.
Jan 07, 2015 | Standard 1991-1993 Oldsmobile Cutlass...
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Transmission speed sensor
It looks like a spark plug on the side of the transmission case with wires running to it. Easy to change.
Sep 20, 2014 | aFe 2001 Chevy Cavalier - 2.2L 4-cyl....
Why is my retrieval tank light on when its empty hoover f8100900
Hi Tara! Try removing the dirty water tank and replacing it. If the dirty water tank is seated properly, you may have an issue with the sensor on the cleaner. We recommend taking the cleaner in to a Hoover authorized service center. Please follow the link to locate the nearest location to you. Thanks!
Service Center Locator
Jul 15, 2014 | Hoover F8100900 Platinum Carpet Cleaner
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Feb 22, 2014 | Essick Air Whole House Digital Humidifier...
Location oxygen sensor number one
your parts store can tell you exactly where it is
Jul 15, 2012 | Air Purifiers
I HAVE 2 MODEL SI861 IONIC BREEZE UNITS. I BELIEVE I BLEW THE FUSES BUT CANNOT FIND OUT WHERE THEY ARE LOCATED. CAN ANYONE PLEASE HELP. THANK YOU.
There may be a thermal fuse in the vicinity of the motor, it may be held to the motor, there will also be one wrapped in the windings just for the motor, or it may just be covered with a section of black shrink wrap. It will have a current rating and a temperature rating as well. Otherwise look closely on the control circuit board as a "pico fuse" really small fuse can be there. It's only indicator will be a current rating like "2A"
Feb 13, 2012 | Sharper Image Professional Plus Ionic...
Jeep rpms fluctuate and car dies 1 mile from start-up
could be voltage regulator is faulty or there could be another faulty sensor. You can test any sensor with an ohmmeter.
Nov 24, 2009 | Air Purifiers
AM Auto Parts 2006 VW Touareg Mass Air Flow Meter Sensor for Models with V8-4163c Logo
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
