Question about Krups Coffee Makers & Espresso Machines
Krups XP5240 very loud pop sound while steaming
I got my Krups XP5240 machine for about a week. Couple of days ago before frothing some milk for my cappuccino I was letting some steam out of the wand as usual to get rid of condensation when suddenly the machine made a really loud pop sound like something exploded inside. Once again, I just turned the steam on in an empty mug for like 20-25 seconds and nothing more than that. After the pop sound it went on as normal, still steaming, no burning smell, nothing. I was just wondering if it was some sort of airlock or something really cracked inside. I used it couple of times after, steamer was ok.. I only noticed some water dripping between portafilter and group head while brewing, pretty sure it didn't happen before the "big bang".. Please help me out with some ideas, the machine is brand new, I really dont know whether I should do something about it or not. Big thanks in advance!
  • Krups Master
  • 1,317 Answers
Take it back to the retailer, tell them about the noise and the water leak. It's under guarantee so you should not be looking for any self help solutions, it's faulty.
Posted on Mar 18, 2017
4 Suggested Answers
SOURCE: Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Posted on Sep 22, 2008
falter
  • 245 Answers
SOURCE: No froth
ing it back to store and tell them ur problem....u can ask for repair or a new machine
Posted on Apr 19, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
I have a Krups Espresso pump XP5240 and as like many people am having problems with the steam wand. The first one disintegrated in the plastic thread area. My new one keeps blowing off when steaming,...
My XP5240 also started blowing the steamer wand off after about 3 months of use, despite fiollowing the Krups cleaning instructions. Here's what I did to fix it.
A: The Problems.
The wand has three holes in the coffee end (center, and on each side). The center hole gets blocked with milk residue. This causes a pressure build up in the wand assembly, and eventually this is enough pressure to overcome the three gripping clips that hold the wand to the nozzle tube. I suspect this was an intentional design for safety. It's unfortunate that it also sprays the user with milk when it lets go.
The second problem is that removing the wand requires that the outer clip retainer ring to be slid down to release the clips. Many users don't realize this and try to pry or twist the wand off. This breaks the clips.
B: The Solution
The wand has to be regularly and throughly cleaned. Just soaking it is not enough. Do it this way:
1. Slide the clip retainer ring down, and then hold the steam tube and gently move the wand straight down. DO NOT try to twist the wand to one side, or you WILL break the clips.
2. Holding the ring, unscrew the coffee nozzle end. The wand separates into three parts: Outer tube, inner steam tube and decorative cylinder.
3. Use a needle or very fine wire (approx 0.4mm) to clear the three holes in the coffee end nozzle.
4. You now need to clear the metal wand tube of milk residue. I found that a 7/64" drill bit was perfect to do this, as it fits snugly in the tube. The amount of gunk removed was surprising.
5. Blow the tube clear from both ends. If it's clean, you will be able to see light through all three holes. If not, go back to step #3.
6. Make sure that there is no milk residue on the steamer tube nozzle where the wand clips on. Milk contains fat, and this is an unwanted lubricant.
After cleaning, my steamer works properly for several days. I also located a 21mm ID O-ring at the local hardware store to hook over the clips. This provides a bit more clip gripping pressure, but will still allow the wand to come off should steam pressure gets excessive.
Aug 02, 2011 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
Frothing
You should try to hold the steam end half a centimeter lower the top surface of the milk and try to have it with a slight angle in the pot with milk and near to side of the milk pot about 1 centimeter. If the steam end goes very near to the top surface of milk and for seconds goes above and then back into milk this can create the bigger bubles foam milk.. So with a very steady hand you can create very nice smooth foam. Also remeber that should stop heating anymore the milk after 72 degrees selcius the point at which you can not leave your hand out on the pot for more one second this point you must stop. After the 72 to 75 degress you could burn the milk protein and any foam already created will desapear just like that.
Try also in youtube "milk frothing" and you find many videos on how to do it.
Good luck.
Remember top vote for this answer
Mar 09, 2010 | Coffee Makers & Espresso Machines
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
No froth
Make sure the small metal tube is clean as well as the holes in mounts into. The tube can be removed easily from the rubber ends and cleaned. I've had my unit for a year now and we use it ever day without this issue ever happening. I did have the constant beeping water leaking from the seat/valve problem which I fixed by opening up the unit and tightening the screws.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Frother doesn't froth
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
96 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
