Sony tv model kv 29m87
I need an line output transformer for the above model Sony Tv , the transformer part no: Nx-4009/M
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Contact the authorized service center for Sony.
Posted on Jul 16, 2013
5 Suggested Answers
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
var-pun
  • 331 Answers
SOURCE: how do I add/remove channels on my sony tv? our
i do not actually know the model
but what you can try is that do a MANUAL TUNE on channel 3
to get whatever channel you previously had
You might have to go to the Menu and then find this option
Do not do a "Auto tune " this will start scanning for all the channel and automatically give them a location
if you have any other problem
pls tell me
Posted on Feb 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
Posted on May 05, 2009
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
Sony 29 flat tv model KV-XR29M8O PICTURE HORIZONTALLY SIFTED
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Sep 25, 2016 | Sony FD Trinitron WEGA KV-XR29M80 TV
EHT NO. OF SONY T.V. MODEL KV-L34MF1 AND APPX.COST OF IT
The line output transformer to your TV should be checked and replaced.
Aug 27, 2012 | Thomson 14MG135 14" TV
I NEED THE FLYBACK PART NUMBER FOR TV SONY MODEL KV-20M40.
This model's flyback part no. is 1-453-210-11 (NX-1731/X4E4)
Hope I helped you.
Jdvillanueva
Jun 13, 2011 | Sony KV-20M40 20" TV
SONY MODEL KV-G14Q2S TV IS ALWAYS ON STAND BY INDICATOR AND REMOTE SENSOR INDICATOR LAMPS AND TIC-TIC SOUND GENERATES FROM CHOPPER TRANSFORMER
The SMPS sounds as if it is OK. The line output transistor has probably failed and maybe the transformer. Before leaving it as repaired, check the tuning capacitor across it and check the 135volt HT line for stability.
Hope that helps.
Feb 16, 2011 | Sony Televison & Video
Looking for part 859796900 for the Sony KV-27V36 27" TV. Apparently that's the transformer. No one seems to have the part, including Sony! TV is 10 yrs old and kaput without it. Help?
What Transformer is that? It doesn't sound like a Sony Part #
The flyback transformer fir this model is listed below:
1-453-207-11 TRANSFORMER, FLYBACK NX-2609//X4C
Oct 26, 2009 | Sony KV-27V36 27" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 2002 Model # KV-32HS500 stand by light blinks 7 times, pauses and repeats. No picture or sound.
7 times blinks shows problem in Horizontal Deflection stage of tv and possible defective part can be Horizontal Output Transistor or Fly back Transformer.
If your are qualified tech person then go ahead to check above parts.
Sep 17, 2008 | Sony Televison & Video
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
