Question about Sony Pvm-20m2mdu Triniton 20" Crt Color Video Medical Monitor Must See$
Screen goes black but volume is still there - Sony Pvm-20m2mdu Triniton 20" Crt Color Video Medical Monitor Must See$
Why does it have black screen?
Sounds like corrupted firmware. Update the firmware with latest version and check. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 30, 2015 | LG Televison & Video
My 40"flat screen TV goes black after ahwile the
Check its backlight inverter board, and CCFL lamps. In most cased, the back-light inverter board might need replacement. Check all the CCFL lamps too for any black edges.
Jun 10, 2013 | Televison & Video
Hitachi 55VS69 screen goes black and there is no volume and it will not turn off unless unplugged.
The key here is you have to unplug it---it means the problem is related to the microprocessor which may become confused because of an issue elsewhere in the set---no real easy answer except it may be expensive to locate and fix.
Mar 19, 2012 | Televison & Video
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
Just goes to black screen
It under mfc warranty contact dealer you purchased it from for repair or exchange.
Aug 29, 2009 | Vizio L37 Television
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
How di I get my K850i to show the time in screen saver mode
Press the volume button on the side of the phone to display a screen similar to previous Sony Ericsson Cybershot phones during standby mode. It will display the time and a message icon. This is probably an energy saving feature when the screen goes black in standby mode, but you must press the volume button to get to that screen.
Feb 25, 2008 | Cell Phones
Sony Pvm-20m2mdu Triniton 20" Crt Color Video Medical Monitor Must See$ Logo
91 people viewed this question
Top Sony Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Sony Science and Laboratory Expert? Answer questions, earn points and help others
