Question about Astro Pneumatic Ast4550 Air Operated Paint Shaker
I purchased a Astro paint shaker ast4550 before I used it I lost the two parts that were in aclear plastic bag that I need to replace any suggestions
  • Astro Pneumatic Master
  • 16,181 Answers
What was the function of the parts that you lost?
Posted on Jul 21, 2013
Tip
Generic, All Around Useful Painting Tips...
When faced with an expensive Paintbrush with dried paint, don't toss it, Save It...
  • Soak it overnight - Starting out with very warm Vinegar.
Now so it doesn't happen again...
  • Clean well, Place it into proper sized Ziplock Bag & then put into a Pringles, or Coffee can, Then cap it with the plastic Lid.
When storing a partially used can of paint, instead of just putting the lid on it,
  • place a sheet of plastic sheeting like Saran Wrap over the top, then press the lid on.
Instead of using the edge of the can to remove excess paint,
  • find a large thick Rubber Band, or Tie a wire or Twine over the top and bottom, exposing it over the middle of the opened can. Now just use that to remove excess paint & it will fall directly into middle of can and keeps can clean.
If your painted project appears a little rough after painting...
  • Don't use sandpaper or steel wool to remove roughness, that will leave scratch marks, even if gone over lightly, instead use Brown Paper Bag.
If going to apply new coat or 1st coat over metal,
  • wipe down really well with Vinegar. This will help keep paint from bubbling, chipping, blistering or peeling away.
To keep paint brush marks from being noticeable, especially on furniture or cabinetry, or Doors,
  • Use a product called Flotrol. This will eliminate streak and brush marks.
And one more tip
When needing to know what type of paint is on your project that you want to repaint...
  • Pour some Vinegar on a cotton ball, then rub on the paint. If cotton ball has paint on it, it is Latex, Not Oil based.
Happy Painting
on Jun 14, 2015 | Crafts & Hobbies
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
How much plaster of paris do i need for a ben10 shaker maker?
140g including the plastic bag - I weighed it before I used it the first time
Jun 08, 2011 | Hardware & Accessories
Recently lost gun in water for a moment, Now scope gets fogged inside. Is there anything I can do to stop it? It a fairly new scope.
Your scope may not be hurt if water has not caused any rust yet. Things you will need, (1) hair drier, (2) Vaseline, (3) large clear plastic bag, (4) gas from a paint ball gun canister or similar type of inert gas you can use. Remove the eye piece, and shake as much water out as you can. Use the hair drier and heat the tube up, not too hot but warm, to dry the inside as good as you can, keep after it, shaking it and heating it. Once you feel all the water and moister are gone. Put a good amount of vaseline on the threads of the eye piece. The put the scope, the eye piece in the plastic bag. Use the paint ball gas and inflate the plastic bag, tie off the bag leaving room so you can screw the eye piece back on the main tube. Leave the scope in the bag for a few minutes before you do screw the eye piece on letting the gas fully get in the tube. The gas will give a bit of positive pressure inside the tube, Will displace any other air that will have moister in it. Keep the inside from fogging back up. The vaseline will help seal the gas inside. Hope this Helps Fix Ya up.
Apr 25, 2011 | Bushnell Sportsman Rifle Scope 3-9X 40...
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Harbor freight pneumatic paint shaker wont shake. How to repair?
If it is new, return it to the store for another. Let them fix it.
May 20, 2010 | Astro Pneumatic Paint Shaker Stand
I have a G4 and the plastic at bottom of bag is cracked
Hi There,
Well sort of. For the G4, the bottom boot is sold with the internal fill tube that inside of the outer bag, where the paper bag connects. These two parts are sold complete as an assembly already put together. You'll just need to take off the strap at the bottom of the boot that holds the outer bag onto the boot. This strap is sometimes difficult, and sometimes it's easier to just purchase a new strap and install it.
Here are direct links to the parts that you'll need on our website:
Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S
And here's the bag strap that you may just want to purchase so you can just cut the old one off:
Kirby Vacuum Bag Clamp. Kirby Part # 196599S
If you have any questions about how to change this part out, please feel free to open a new repair, or just use the comment field here on Fixya. If you found this repair helpful, please follow the Fixya way and leave feedback for the repair. This is really appreciated when someone answers your repair questions, and is what keeps repair professionals continue to post free answers rather then just the paid ones. Thanks again,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Kirby G4 Bagged Upright Vacuum
Control the volume on each of the 12 bass shakers i plan to install
Please note that you can't simply wire them together in series or parallel. Connecting any more than 2 would likely cause damage to your amplifier. (depending on the impedance of the bass shaker 4 ohms, 8 ohms, etc.)
The Buttkicker brand recommends the following configuration for four buttkickers into one amp: Click here
As you can see, you need a combination of parallel and series connections to make sure the amp is "seeing" the correct load. I'd recommend purchasing three dedicated subwoofer amps (there are some good inexpensive ones at http://www.parts-express.com.
This will give you volume control over each set of four shakers at the amp itself. If you need control at each shaker, the only solution I know if is to use an impedance matching volume control.
Check Parts Express for those, too.
If this solved your problem, please rate it as FixYa. If not, let me know how else I can help you.
Apr 21, 2009 | Audio Players & Recorders
Astro Pneumatic Ast4550 Air Operated Paint Shaker Logo
Top Astro Pneumatic Air Tools & Compressors Experts
Trippy Tripp
Tom Chichester
Are you an Astro Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
