Sony trinitron screen goes black - Televison & Video
  • 1694 Answers
SOURCE: Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Posted on Oct 03, 2007
BMW Rider
  • 232 Answers
SOURCE: Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Posted on Feb 27, 2008
freetek
  • 5568 Answers
SOURCE: tv fix
I'm pretty sure the power supply is in the process of failing.
I'm pretty sure the problem is caused by a 50 cent (maximum!) part called a capacitor in the range of 4.7 - 100 uFd that is responsible for feed back that keeps the power supply ticking. If you decide to have it repaired and the problem is as above, tell the tech to use a low ESR part and add a .1-.5 uFd ceramic capacitor in parallel to the one he/she replaces. That cap will handle the fast rise times that causes the electrolytic cap to break down chemically and fail.
Before you toss it out, just take a few minutes and do searches here at Fixya on rear projection, LCD and plasma TVs. The failure rate across all brands is staggering and many of them are suffering the type of problem you are currently having but seemingly the majority are under two (2) years old. If you do decide to replace it, due diligence may save you a lot of anger if you check to see how the model or brand you are interested in is faring.
I have one Wal-Mart turkey (iLo) that is a miserable conglomeration of cheap parts and unpredictable performance.
Posted on Oct 31, 2008
  • 4234 Answers
SOURCE: a black rectangular black screen shows up but..... sony trinitron
Check the set up. You may have closed captioning turned on which will show up as a black box if there is no closed captioning information for the selected channel. If that fails to resolve the problem, update this.
Thanks,
Dan
Posted on Aug 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: sony trinitron xbr screen periodically goes black
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Posted on Feb 20, 2010
Testimonial: "It sounds like you know what you are talking about."
Hi there. I have a Sony Trinitron KD-28DX200U. There's no picture and the red light flashes 15 times.
TV has gone to trinitron heaven. Give it a decent burial and time to move on.
Aug 12, 2015 | Sony Televison & Video
Screen goes to black
The main power regulator section circuit should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 05, 2013 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My sony trinitron screen goes black and the standby light blinks
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
Jul 11, 2012 | Sony Televison & Video
Older Sony Trinitron screen goes out but not the sound
Hi
Look through back of set when fault is on , can you see crt heater lit in neck of tube it not resoldered all connection from flyback transformer to crt base. If heater is lit then fault is due to a video drive fault not a easy to find without test gear.
regards windyhouse
Mar 29, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
A black rectangular black screen shows up but..... sony trinitron
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a UK sony trinitron kv-32wf1u with Black Screen
it could be one of the closed-caption settings. make sure the cc is off. if the problem remains, you may have tuner issues.
Jul 31, 2009 | Sony Televison & Video
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mar 07, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
