Question about Refrigerators
Lg refrigerator model gr-t632dvq
Freezer works if on high setting not mid range and fridge is running at room temp even on high setting....any help on this issue?
  • 19 Answers
SOURCE: Refrigerator LG Model GR-T452G freezer works but
Locate your defrost timer, they are either in the buttom front of the refrigerator, in back of the refrigerator, or inside compartment behind the plastic covers. On the defrost timer there is a slot were it can be turned using a screwdriver, or there is a round window were you can see it running.when you turn this dial and it clicks, you should now go into defrost. with all the ice build up in your evaporator you should hear the ice cracking indicating that the heaters are working, if not you might have open defrost heaters.
Posted on Feb 21, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
woodchuck789
  • 4066 Answers
SOURCE: refrigerator cooling issue
If it's not a defrost problem then it will be a freon/compressor problem which has a 5 year warranty.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jan 01, 2010
SOURCE: Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Posted on Jun 19, 2010
heatman101
  • 43501 Answers
SOURCE: LG Refrigerator Model GR-721R
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 12, 2011
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Mar 02, 2009 | LG LFD25860
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
