Question about Electrical Supplies
Search Fixya...predator 3200 generator manual
Hi, i have a 3200 watt predator generator, it has a rubber tubing from the top of the gas tank to the filter what is this for?
frcs68
  • 1605 Answers
SOURCE: fuel supply
no. the generator fuel is gravity feed.
you can install a fuel pump, but then you going to need additional wiring and hardware.
Posted on Apr 09, 2009
protek480
  • 1714 Answers
SOURCE: New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Posted on Jun 30, 2009
  • 197 Answers
SOURCE: I'm looking for the 2 cycle oil to gas dilution
20:1 that's 1/4 pint to a full tank of fuel.
Posted on Jan 17, 2010
  • 1082 Answers
SOURCE: I try to start the generator today (rope pull
! - Do not try to start it.. With all that gas, could literally blow up.
Sounds like the fuel system is not controlling the gas flow. If Carburator, float valve is stuck open. If it's fuel injected, then the diaphram in the flow control maybe rotted out or otherwise malfuctioning, in both cases, allowing the gas to drain down into the manifold, running into the cylinders, and seep into the oil sump past the pistion rings.
Drain and replace the oil, after looking carefully at the fuel supply system.
Posted on Jan 03, 2011
SOURCE: I need a gas tank
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Posted on Feb 25, 2011
I have a harbor freight predator 7000/8750 watt generator i need a wiring diaghram for that generator since my dog ate part of the wiring harness if you could help i would appreciate it
I would go to NAPA and get a butane soldering iron
some wire strippers, rosin flux core solder, shrink tube and a heat gun. Then ..
Don't just look for wiring diagrams for that generator; but,
do some google search on how generators are wired.
That will help you sort out the issue.
you don't wont to wire it wrong, run it and burn up a coil .
Ed
Feb 20, 2017 | Electrical Supplies
Have a steele 6000 will start but then dies
just search on You tube as Pakistan free energy Magnet motor. you will forget generators. See professor Yel free energy magent motor in delft university on Youtube.
Oct 17, 2015 | Steele Products 6000 Watt Portable...
I need a battery for a predator portable generator
Go to WalMart and look at their EverStart line of batteries for motorcycles and ATV's. I have the 8750/7000 watt predator and the EverStart ES9BS works great and fits well on the holder. It comes with the acid and you will need to add the acid and fully charge the battery before use.;
Jul 27, 2012 | Electrical Supplies
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
I need to remove the gas tank from a honda generator eu3000is.
I have a ems 4500 honda, the gas tank looks like the upper bar needs to be removed to get the gas tank off, it does. Follow the
top bar down on each of the corners. Where the top bar meets with the bar below the gas tank, you will find a bolt in each of the tubes. Take these screws out, use a hammer to tap the top bar upward lightly at each corner. You should see the tubing sliding up out of the bottom tubes.
Apr 10, 2009 | Electrical Supplies
Electrical Supplies Logo
113 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
