Question about Canon PIXMA Office Equipment & Supplies
Canon MG5450 Hi, No power on printer. Tried changing the fuse and using another cable with no luck. Please help out. Thanks
Arius
  • 446 Answers
SOURCE: Printer doesn't respond to computer
there were many instances why the computer says "printer is not responding" either it is not configured correctly. for a start..
try this go to start- printer- right click the desired printer- open up properties- then click print test pages-
if it does print then it should work on all platforms, if it doesnt then you might have installed the wrong drivers.
try this first
Posted on Jul 24, 2008
tehnik_bdg
  • 91 Answers
SOURCE: got error of "PC cannot send datga to printer. Please check power
Replace the usb cable
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: Cartridges do not Move & the Printer Shut Downs Automatically
tell if the cartridge iss moving a litle or is totaly bloched
Posted on Sep 06, 2009
joedirty
  • 158 Answers
SOURCE: Canon MP830 - won't turn on
it fried logic board.contact cannon about 100.00 dollors
Posted on Oct 18, 2009
SOURCE: clicking sound and in use/memory light flashes. Canon PIXMA MX850
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
Posted on Nov 06, 2009
How do you change ink for canon mg6450
Open the lid and replace the 'blinking' cartridge.
Sep 01, 2014 | Canon PIXMA Office Equipment & Supplies
How to use canon pixma mg3150 printer
Hi can someone please tell me how to scan a document using the canon mg3150 please thanks
May 06, 2012 | Canon Office Equipment & Supplies
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Epson Workforce 610 will not power up.
Welcome to Fixya. I would like to know if you already try to change the power cable and see if the problem is the cable? What were looking now is that if this problem is cause by a bad power cable or a problem with the internal parts of the printer. It can be the fuse, Capacitor, Transistor or the mainboard itself. If Changing the power cable won't fix the issue you need to have the machine checked for possible repair and replacement of the part that is bad. Please also check if you still have warranty on the system so that the repair will be free.
Thanks
Jul 10, 2011 | Office Equipment & Supplies
I have the canon pixma 160 Inkjet printer.....when tryng to print, it gives me the error message 5010 ...i just refilled my cartridge...also i tried removing the usb wire and switched it off and then...
This error is caused after pulling the printer to bits to fix a blockage. You can fix it by inserting the ribbon cables from the scanner into the circut board properly.
Good Luck!
Aug 27, 2010 | Canon PIXMA MP160 All-In-One Printer
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Canon mp600r won't turn on
Try to unplug the printer wait for 120 seconds and plug it back into the wall for power. Make sure that the power cord is plugged firmly on both ends, at times they become loose, very common. If this does not work please explain when was the last time it worked and anything else that could help to resolve the issue. Thanks
Sep 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Clicking sound and in use/memory light flashes. Canon PIXMA MX850
Brian
Jul 13, 2009 | Canon Office Equipment & Supplies
Canon i560 printer will not turn on, despite power. Is there a reset bntton or combination that may make it possible or is it a short life product?
Have you checked the fuse on the power cable? Have you tried another power outlet and changed the power cable?
If you have the chances are the power supply unit in the printer is faulty. It may have an onboard fuse that has blown or maybe the PSU is fried.
Jul 16, 2008 | Canon Office Equipment & Supplies
124 people viewed this question
old marine
old marine
