Hp vivera i have a hp vivera inks photosmart c4180 printer when i turn it in the screen says "turn power off and turn back on again" what does this mean
    Top Expert:
  • 12,223 Answers
Go to MENU and restore the factory defaulty and try again.
If the problem persist, you must call to the tech, for autotest.
God bless you
Posted on Jul 15, 2013
Riztech
  • 731 Answers
SOURCE: HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Posted on Feb 15, 2008
SOURCE: Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Posted on Oct 05, 2008
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
SOURCE: i have a hp c6280
I had this same problem with my c6280.
I got fed up (HP only added frustration) and decided to trash it and buy something new.
So I figured I would take it apart and see if it was something obvious, worst thing that could happen was that the printer would not work - allready there.
Here is what I found.
Taking the covers off of this printer is not easy, but after removing all accessable screws I was able to get the covers off.
I found the pump motor on the left side of the printer (it is labled).
The pump motor has a large (approx 2 in) gear on it that is drivin by a belt with teeth.
The other end of the belt is drivin by a small (approx 3/8 in) gear.
There are two belt tensioners on each side of the belt.
PROBLEM; The belt was not riding on one of the tensioners.
This causes the belt to intermitenly engage the gears (stalled pump motor).
I put the belt back on the tensioner, put the covers back on (a real pain).
Printer now works fine.
I think that this may have been a problem out of the box because the lound clicking noise that came with the printer has also gone away.
Posted on May 06, 2009
Joed911
  • 4338 Answers
SOURCE: Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 21, 2009
Hp vivera
Try a hard reset of the printer and see if that does it.
Sep 08, 2017 | HP Photosmart C4180 All in One Printer,...
HP Photosmart C4180 message "Scanner
Try resetting the printer:
Reset the printer
-Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
-Open the cover of the printer and remove the print cartridges.
-Close the cover and wait for the Insert Ink Cartridges message.
-Disconnect the power cord from the back of the printer and wait for one minute.
-Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
-Open the cover and reinsert the print cartridges.
-Close the cover. If prompted, print a calibration page.
-Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps!
Feb 07, 2011 | HP Photosmart C4180 All-In-One InkJet...
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
How do i know which kind of ink cartridge will fit in my HP photosmart C4180.
Your printer uses two common ink cartridges, HP 95 (color) & HP 98 (black)
Hope that helps.
Oct 26, 2010 | HP PhotoSmart C4180 All-in-One Color...
C4eb8401 photosmart vivera c4180
http://www.youtube.com/watch?v=dHU_c2TaXs8
Apr 29, 2010 | HP Photosmart C4180 All-In-One InkJet...
How to install cartridge for HP Photosmart C4180 all-in-one
very easy you turn on the printer and open the lid in the front and the ink cartridge should slide to the middle then take the old ink out and follow directions on the package of new ink cartridge
Jun 10, 2009 | HP Photosmart C4180 All-In-One InkJet...
My hp photosmart c4180 wont turn back on after removing ink cartr
the power cord might be faulty.See if the adapter is warming up or nor after connecting it to a power source for at least 20 mins.If it is not warming thencontach HP at 1-800-hpinvent.they replace it for free or a nominal charge.
May 03, 2009 | HP PhotoSmart C4180 All-in-One Color...
Ink cartdge issues w/ Hp C4180 all-in-one brought from US 2 UK.
don't forget U.K. use 220v we using 110v. can't be compatible!
Dec 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Steps:
Thank you ...
Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
jasbo
jasbo
