Question about Exercise & Fitness
BH fitness pioneer start treadmill- flashing E7
I have a BH fitness pioneer star treadmill, it has stopped working and is flashing E7. I don't have instructions. I have been told it could be an incline error but I don't know how to fix it.
    Top Expert:
  • 12,223 Answers
See this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Jul 15, 2013
SOURCE: repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Posted on Nov 24, 2011
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
Daniel S
  • 4323 Answers
SOURCE: Our Nautilus T514 treadmill stops
Hi
Try clearing the error by unplugging the treadmil. if it doesn't clear then try and press stop button for 10 seconds. Insure cable is connected securely to Console. All wires in cable should be intact. If any are cut or crimped, replace cable. If error doesn't go then lubricate the treadmill as given in this manual---
Nautilus Treadmill 514 Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
I have a bh fitness treadmill model number G6414v and its got an e-02 and e-07 error on screen . What do I do
I don't know what this has to do with washing machines???
On your BH F1 treadmill here are their listed errors.
E1
Possible cable fault.
Connect the wire well between top
controller and bottom controller
E2
Burst clash.
Operating with incorrect voltage; Connect
the motor wire again.
E3
No speed sensor signal
Replace the sensor light on the bottom
controller or speed sensor.
E5
Possible motor overload.
Lubricate the belt.
E7
Safety key.
Insert the safety key.
Here is the manual, page 12 is the troubleshooting and error codes in English.
http://www.bhfitness.hu/shop_ordered/69670/pic/english-manual/G6414U_Monitor_manual_v2-3226.pdf
Jul 26, 2016 | Exercise & Fitness
Bh north america
If you haven't already, try this phone # for BH North America
(949) 206-0330
Dec 01, 2013 | Exercise & Fitness
Owners manual BH Fitness G6448N
Check your mail. I have sent you the manual for your treadmill.
Ajin
Apr 26, 2012 | Exercise & Fitness
I need a manual for pioneer pro treadmill
I also need a manual for a second hand one purchased and would be very grateful for an email at dmma4@hotmail.com if someone can help.
Jan 31, 2012 | Exercise & Fitness
Instruction manual
Hi, please can anyone help. Looking for owners manual/user guide for a BH FITNESS PIONEER PRO (PART NO G6448N) Treadmill,
Please email me ell-jay@hotmail.com
Thanks
Aug 08, 2011 | Bladez Fitness BH T8 PRO Treadmill...
It keeps flashing E7 and 1300, 1310, and 1320
I tested the elevations motor to see if it had a short. In doing so the motor reset itself and the treadmill went on performing as normal. I had to refer to the repair manual provided by BH on their website and found what the error code E7 meant.
Jan 07, 2010 | Bh Fitness T8 Basic Treadmill
Exercise & Fitness Logo
543 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
