Question about Garden
Makita eh561 location of spark plug
My makita dbc4010 petrol strimmer was working then not used for 3 months now it wont start,plus now theres no spark
Parts: http://www.ereplacementparts.com/makita-dbc4010-brush-clearing-saw-parts-c-97_16558_10177.html?gclid=CKyA0JLti80CFQetaQodzw0DaQ Use fresh gas and oil, 2 stroke 40:1. Clean/replace air filter and spark plug.
Sep 25, 2015 | Makita Garden
How do i check ignition coil on makita dcs34
Remove the plug leave it on the wire check for spark plug must be grounded.
Oct 05, 2014 | Makita 14" Chain Saw Dcs34
Dolmar ps 34 or makita dcs34
Replace the spark plug and get some starter fluid. Add FRESH gas/oil mix. Spray a couple squirts in the spark plug hole, replace the spark plug and try to start it. I would add Sea Foam (get it at any parts store) to the gas tank and let it run for ten minutes. Go to the manufacturers website, support, and search for your saw by model/serial number.
Mar 15, 2014 | Garden
Spark plug gap for makita dpc 7311
take the cover of a pack of cigarette paper then its most of the times right.
Feb 24, 2012 | Makita Saws
Have a makita gas cut-off saw dpc7321,has spark to the plug but will not start,it is getting plenty of gas too
Is the gas fresh? Is the plug wet with fuel after you try and start it? Have you done a compression test on the engine?
Jul 09, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
What is the spark plug gap for the makita rbl 250 blower
The spark plug gap of this machine is 0.6 to 0.7 mm, or 0.024 to 0.028 inch.
An owners manual is still available from Makita if you go to their website.
Nov 26, 2010 | Garden
Kia ora, i have a makita 2 stroke grass cutter, that just wont start, checked, spark plug, fuel, took it apart and cleaned it..still wont start. Please help, it does not have model number only product...
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
Oct 08, 2010 | Makita Garden
New makita chainsaw difficult to start. Any suggestions?
sue fresh 2 stoke fuel and buy a new spark plug
Aug 05, 2009 | Makita Garden
I am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
use a regular post card inserted bet fly wheel and mag close enough
Oct 05, 2008 | Makita Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
