Page en francais erreur 980 pour oki 5750
Apres avoir alime vous verrai le message suivant service call 980 fatal error
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
gremlin11
  • 78 Answers
SOURCE: epson acculaser c1100 service req E521
the developer home position sensor is not registering. it will need to be cleaned. This will involve the removal of the left side cover, the removal of the power supply pcb and the removal of the sensor which sits under the power supply. clean the sensor out with a dry pain brush and re install. be careful to turn the printer off and unplug it prior to removing any covers. the cover is easily removed, however, take your time and make sure you release all the clips on the inside of the cover. once the cover is off it is easy to get to the sensor. don't worry too much about all the connections to the power supply, they only fit in one plug and cannot be inter changed.
Remember to take your time in this operation. If you are at all uncomfortable with this, do yourself a favor and call a technician in to do it. He wii do it in about fifteen minutes.
Gremlin11
Posted on Dec 10, 2008
  • 13 Answers
SOURCE: OKI C5900
Most likely you have paper wrapped around the fuser or at least stuck in the fusers sensor So remove anywhere you can see paper. If not it will need a replacement fusing unit.
Posted on May 01, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: How do i solve fatal error 980
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
Samsung bloqué par opérateur
Qu'est-ce qu'un code PUK? Un code PUK (Pin Unlock Key) est nécessaire lorsque vous entrez un code PIN erroné 3 fois. Après avoir entré le code PIN erroné 3 fois, la carte sera verrouillé et vous devez obtenir un code PUK auprès de votre prestataire de service pour le déverrouiller. Que devez-vous faire si votre téléphone dit Entrez le code PUK Code? Vous pouvez recevoir des appels de code PUK de votre de fournisseur, soit en vous connectant à votre compte sans fil à mon compte; visitant notre Chat d'assistance technique ou en téléphonant au service à la clientèle. Une fois votre code PUK a été reçu, il sera nécessaire d'entrer dans votre téléphone pour définir un nouveau code PIN.
Si le mauvais code PUK est entré 10 fois d'affilée, la carte SIM devient invalide (verrouillées en permanence) et vous devrez acheter une nouvelle carte SIM. Le téléphone affichera «PUK bloqué opérateur d'appel» ci-dessous. Si votre périphérique a besoin d'PUK 2 s'il vous plaît appelez à la clientèle: soins. Pour obtenir votre code PUK, en log myWireless compte et suivez les étapes 1. Sélectionnez Téléphone & Device 2. Sélectionnez le lien Débloquer la carte SIM 3. Suivez les instructions sur le pop-up page Comment débloquer votre carte SIM Vous aurez besoin de votre téléphone dans la main afin de débloquer votre carte SIM. 1. Tout d'abord, entrez le code PUK chiffres 8, puis appuyez sur OK / Oui:. Remarque: Certains utilisateurs de téléphones Motorola devrez entrer ** 05 * si "Entrez le code PUK» n'est pas déjà affichée. Après avoir entré ** 05 *, puis entrez le code PUK chiffres 8 et appuyez sur OK. 2. Choisissez un nouveau code PIN, puis appuyez sur OK / Oui. 3. Re-entrer le code PIN, puis appuyez sur OK / Oui. 4. Si les codes ont été conclus avec succès, le téléphone est prêt à l'emploi.
J'espère que cela vous aide, ecuse mon mauvais français.
Dec 04, 2010 | Samsung Computers & Internet
HP photosmart C6180 tout-en-un message d'erreur Err Oxc18a0106 BESOIN URGENT D'AIDE EN FRANCAIS .MERCI
Retirer les cartouches du produit.
afficher sur le panneau de contr?le. " xc="1.Wait for the 'Insert Cartridges ' message to display on the control panel." closure_uid_u4snr0="101">1.Wait pour le message "Ins?rer les cartouches" pour afficher sur le panneau de contr?le.
produit. " Xc="1.Disconnect the power cord from the back of the product." closure_uid_u4snr0="102">2.D?connectez le cordon d'alimentation de l'arri?re du produit.
secondes. " Xc="1.Wait 60 seconds." closure_uid_u4snr0="103">3.Attendre 60 secondes.
4.Rebranchez le cordon d'alimentation. produit n'est pas automatiquement en marche, appuyez sur le bouton Power (). " Xc="If the product does not automatically turn on, press the Power button ( )." closure_uid_u4snr0="105">Si le produit n'est pas automatiquement en marche, appuyez sur le bouton Power ().
cartouches, puis fermez toutes les portes ouvertes sur le produit. " Xc="1.Reinsert the cartridges, and then close any open doors on the product." closure_uid_u4snr0="106">5.R?ins?rer les cartouches, puis fermez toutes les portes ouvertes sur le produit.
vous recevez une invite pour imprimer une page d'?talonnage, le faire. " Xc="1.If you receive a prompt to print a calibration page, do so." closure_uid_u4snr0="107">6.Si vous recevez une invite pour imprimer une page d'?talonnage, le faire.
USB ? l'arri?re du produit, puis relancez l'impression." Xc="1.Reconnect the USB cable to the rear of the product, and then try printing again." closure_uid_u4snr0="108" >7.Rebranchezt le c?ble USB ? l'arri?re du produit, puis relancez l'impression. si>vous avez suivi toutes les ?tapes ?num?r?es ci-dessus et connaissent encore un probl?me, le service du produit
Dec 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Aprés remontage batterie (suite à
Salut , ZE_silva pour cette situation je appeler mon revendeur local ou le service / d?partement de pi?ces de magasin de renom et se renseigner sur tout ?ventuel correctif rapide, r?ponses , ou d'une enqu?te de pi?ces. Si n?cessaire , le transport de votre moto chez le concessionnaire ou un magasin et demandez ? un technicien professionnel de le prendre pour un essai routier , si elle est en ?tat de marche , et vous donner une estimation ?crite des r?parations et r?pondre aux questions sp?cifiques que vous pourriez avoir au sujet de votre probl?me. Pour plus d'informations au sujet de votre question et t?l?chargements gratuits que vous voulez s'il vous pla?t visitez les sites Web ci-dessous . Bonne chance et bonne journ?e . https://www.tradebit.com/filesharing.php/search/0/bmw+f800s
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
Hints and advice for BMW bike motorcycle owners K1 K75 K100 K1100 bulb...
Nov 28, 2010 | 2008 BMW F 800 ST
J'ai egare le pass code du motorola h670 que doive faire blue tooth
Salut,
Le mot de passe est 0000 (quatre z?ros)
Pour plus de d?tails, t?l?charger et consulter le manuel au format PDF en cliquant sur ce lien.
S'il vous pla?t noter: Adobe PDF Reader est requis pour visualiser ce manuel. T?l?charger Adobe Reader.
Merci pour avoir utilis? FixYa.
S'il vous pla?t note: je suis l'aide de Google Translate pour poster ce message. S'il ya une erreur, merci de pardonner.
Oct 28, 2010 | Motorola Mobility H670 Headset
Bonjour je voudrait avoir le manuel d'intruction pour un appareille photo vivita vivicam t026.sur se qui se trouve dans le menu exemp:scene,resolution de l'image etc.je vient de tout perde mes photos de...
je voudrai avoir le manuel d utilisation en français car je ne comprend pas l anglais le manuel fourni est en anglais pouvez-vous me le faire parvenir par mail c est pour un a^ppareil photo vivicam 4090 merci mon imail nefertiti42@live.fr
Jul 31, 2010 | Vivitar Cameras
Problems
you will need to contact your mobile service provider helpdesk for further assistance on this matter.
Jun 01, 2009 | O2 Samsung SGH-E250 Cellular Phone
Bonjour, je n'arrive pas ? ouvrir mon doculment Word : le message suivant appara?t : impossible d'ouvrir le document word essayez les op?rations suivante : fichier ,ouvrir .... / V?rifier que le document...
Essay de installer Open Office (cet gratuit) et apres ca, essay de ouvrir le meme Word document avec Open Office Word.
Bon chance
Pour telecharger OpenOffice en Francais regard
http://fr.openoffice.org/
Ciao
Jan 27, 2009 | Computers & Internet
Je nai pas de pression au bout de la brosse
Je suis désolé mais Fixya a seulement une version anglaise en ce moment. Cependant ce site vous permettra de copier et coller n'importe quelles réponses vous pouvez devoir votre problème pour que vous pouvez les lire en français. Vous pouvez taper aussi votre question sur ce site et cette copie et ce passé la traduction l'anglais sur Fixya pour une réponse plus rapide des experts.
Le site de traduction mentionné est un site de traduction libre. Juste être sûr de choisir les langues correctes pour la traduction à et de.. (L'anglais à français ou français à l'anglais) et utilise le bouton de Traduction LIBRE.
http://ets.freetranslation.com/
Merci pour utiliser de fixya. ..and j'espère que ceci aide ! ! !
Dec 22, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Ne marche pas apres changement de cartouche
1- etre vous sure d'avoir enleve la bande plastic
2- quelle est le message exact? "cartouche pas reconnue"
3-si vous remmetez l'ancienne cartouche la reconnait t'elle?
4- si, oui la nouvelle cartouche est defective
5- vous avez pris une grosse chance en postant en francais.
Dec 10, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
73 people viewed this question
jasbo
jasbo
