Question about Brother MFC 420CN All-In-One InkJet Printer
Cant print in black
Hi i cant print in black but i can in every other color
  • 832 Answers
Do the cleaning procedure twice. Use a original brother ink cart! If you are lucky, the printhead is not clogged. If you dont see any black blocks when printing the testsheet, the head is definitly clogged. You cant clean the printhead because of an internal filter!
Posted on Sep 10, 2007
SOURCE:
I would like to print some color pictures in black & white but I cant get it to do it. Any ideas
The black ink produces dark images while color ink produces multicoloered images. Once pictures that appear in color on the computers word documents are dispensed for printing, the color ink makes possible requests. It is impossible to request black charaters from colored ink on the printer.
Feb 04, 2011 | Lexmark X4580 InkJet Printer
I cant print in color
For reasons known only to Brother you are unable to print ANYTHING if you are out of any color of ink. If you are out of black and need to only print in color it WILL NOT work
Feb 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
Color is low but cant print black on printer paper runs through blank
good day, if nothings coming up then u might need to run a maintenance check, use cleaning then test print and see if somethings changed. hope this helps, have a nice day
Feb 07, 2010 | Canon PIXMA MX310 All-In-One Printer
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
If your trying to only print form a tri-color in cartage and you dont have a black cartage in the 2nd slot as well you might try doing the following
I am not sure whether u can print only using one cartridge(color) with this All-in-One. Check out the following steps nd let me know if they have helped.
1. Remove the Black cartridge from the All-in-One.
2. Open HP Director.
3. Click Settings -->> Print Settings --->> Printer Toolbox.
4. Under the Configuration tab, select One Color cartridge from the drop down list and click apply.
Now,try printing.
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
120 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
