Question about AOC Televison & Video
Flat screen tv cant get menu to come up
I have a aoc l24h898 tv that I think the backlight is going out of but before I go any farther with it I cant get the menu to come up to get to settings. The buttons are not locked. Thanks!
    Top Expert:
  • AOC Master
  • 75,311 Answers
If there in no menu display, the main digital board to your TV shoule be checked. Contact any service technician.
Posted on Jul 15, 2013
SOURCE: My son bought an AOC LCD TV (model L24H898) last
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Posted on Feb 24, 2010
SOURCE: child lock reset
1. Turn the television on.
2. Hold VOL - ON TELEVISION and SLEEP on the REMOTE.
3. When self-check is displayed, press any button.
Posted on Oct 22, 2008
SOURCE: unlocking tv button lock
MY KIDS WERE PLAYING WITH THE BUTTONS ON THE TV NOW WHEN I TRY TOO CHANGF THE CHANNELS OUR VOLUME TV BUTTON LOCK ORTV BUTTONED POPS UP.I DONT HAVE MY REMOTE SO WHAT IS ANOTHER METHOD?
Posted on Jan 16, 2009
  • 90 Answers
SOURCE: DELL LCD TV locked up w/screen message "main menu locked"
without a remote and disabled keypad keys, the only other option, is to open the unit up a physically RESET the TV. remove the cables from the power board. i believe it has a phillips head screw. careful when you separate the rear cover from the front cover. there is a board screwed in the lower right corner, there is a connecter and a ground cable screwed to the rear cover. take your time prying on the rear cover. once you separated the two pieces, look for the light yellow board with your AC power source. Unplug it for 30 minutes and repeat the process. while your at it, also look down to the lower left side of the monitor. u should be able to see the keypad. press each button, while pressing, look to see if the button is pressing against the circuit board. it may be loose, try this test, u just may be able to fix your keyboard as well. hope this works out.
Posted on Jan 30, 2009
SOURCE: I have viewsonic flat screen tv and it displays
you have to hold the 2 volume buttons on the top of TV down at the same time.
Posted on Nov 22, 2009
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | AOC L24H898 24 in. LCD TV
How do you reset an AOC tv ?
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
May 03, 2014 | AOC L24H898 24 in. LCD TV
I tried to turn my tv on and the light turned blue for a couple of seconds and turned red again
Might be component failure.
Check your technical support first.
If they cant help, go for service centre.
Mar 22, 2014 | AOC L24H898 24 in. LCD TV
Factory reset
Try this for factory reset:
Jan 22, 2014 | AOC L24H898 24 in. LCD TV
Reset button
Try this:
Jan 14, 2014 | AOC L24H898 24 in. LCD TV
Service mode aoc lcd tv
This sounds like a common problem on these TVs. Try a factory reset:
3. *A small screen should appear in the top left part of the screen.
If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
Mar 05, 2012 | AOC L24H898 24 in. LCD TV
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
How reset L24H898
Hello
From Menu options come to "Option" window. Highlight "restore defaults' and press "Enter". The set will automatically restore to Factory default settings. OK.
Apr 29, 2011 | AOC L24H898-24 LCD TV
No tengo menu en lcd aoc L24H898
mi televisor se quedo azul se ve la imagen azul y se quedo sin sonido al presionar los botones dice " button locked"
Dec 15, 2010 | AOC L24H898 24 in. LCD TV
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
Televison & Video Logo
163 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
