Question about Cooktops
Defy gemini masterchef wiring diagram
Can you please assistas how to wire up new hob with 4pins on plate to old hob with 6 pins on plate
5 Suggested Answers
  • 3 Answers
SOURCE: What thickness cable should be used?
15 amp cable
Posted on Jul 20, 2009
  • 32 Answers
SOURCE: just bought new electric hob to replace old one
WHEN YOU OPEN THE TERMINAL YOU NORMALLY FIND A CIRCUIT DIAGRAM IN THERE. YOU WILL HAVE AN EARTH, NEUTRAL AND LIVE TERMINAL. IT IS NORMALLY MARKED ON THE TERMINALS. GOOD LUCK. MAKE SURE THAT YOU SWITCH OFF THE POWER TO YOUR STOVE POINT TO MAKE SURE YOU DONT SHOCK OR GET AN ELECTRICIAN TO DO IT FOR YOU. THATS THE SAFER OPTION.
Posted on Sep 07, 2009
rickead1
  • 1998 Answers
SOURCE: removed faulty oven switch and drew wiring
what is the make and model number of your cooktop? Thanks
Rick
Posted on Dec 19, 2010
SOURCE: 5 amp fuse for Lights,Warmer & Rotissorie switches for defy 420 4 plate stove
im sure u using the wrong amperage fuse
Posted on Dec 28, 2010
Electrical wiring of Indesit hob PI 604 GB
I do not have the wiring diagram, here is the user manual, hope it can help
Jun 24, 2008 | Cooktops
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
