Question about Photography
I have a 35mm Chinon CP-7m camera. It was not in use for some time and suffered some battery leakage. Basic functions not working. Cannot load film, motordrive no power. Can it be fixed without large costs?Gert van RensburgMokopaneLimpopoSouth AfricaI would appreciate hearing from you.
SOURCE: nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Posted on Feb 09, 2008
  • 185 Answers
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
  • 138 Answers
SOURCE: light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Posted on Jul 14, 2009
  • 102366 Answers
SOURCE: I dont know how to load my Nikon 35mm camera. I need instructions
Pull up the film rewind knob to open the back.
Drop the cartridge into the well on the left and, while rotating the rewind knob, push it back down to secure the cartridge.
Pull the leader across and insert it into any of the slots in the takeup spool.
Make sure the film perforations engage the sprocket teeth.
Alternately wind the film lever and press the shutter button until the perforations on both edges of the film engage the sprocket teeth.
Close the camera back, making sure it latches.
Take up the film slack by rotating the rewind knob in the direction of the arrow until you feel resistance.
Make blank exposures until the counter shows "1".
There's a fuller, illustrated set of instructions in the manual, which you can download from http://www.butkus.org/chinon/nikon.htm
Posted on Feb 03, 2010
SOURCE: Powers on, wont load film, beeps constantly, Can't select a mode,
I had a similar problem today with my camera. I'm not an expert on Cannon cameras or any cameras for that matter, but this is what I did to fix the problem.
I removed the bottom cover(has 6 screws i believe) carefully sliding the cover up starting near the battery cover. Holding the camera still I checked what gears I could to make sure they were free, but one small gear that moves up and down was stuck. I applied a very small amount of force to the gear to free it, reattached the cover and all the screws, and BAM! I was back to taking pictures.
Hopes this helps.
p.s if you can't find one of the screws its under the battery cover flap :).
Posted on Jul 22, 2010
How to load Nikon F50 camera
The F50 is called the N50 in some parts of the world.
The film loading instructions are on pages 10-11 of the N50 manual available from http://butkus.org/chinon/nikon/nikon_n50/nikon_n50.htm
Jan 28, 2014 | Nikon FG 35mm SLR Camera
How does the back of the camera open to load film?
Unwind the film rewind crank and lift up.
If you need a manual, you can download one from
http://butkus.org/chinon/minolta/minolta_x-370/minolta_x-370.htm
Sep 20, 2011 | Minolta X-370S 35mm SLR Camera
I don't know how to load or unload the film for my Minolta x700
You can download the manual from
http://butkus.org/chinon/minolta/minolta_x-700/minolta_x-700.htm
There are illustrated instructions for loading/unloading film beginning on page 17.
Feb 22, 2011 | Minolta X-700 35mm SLR Camera
1) Minolta XG1 35mm Film Camera 2)Minolta X300 35mm Film Camera Which batteries can I use for the cameras listed above?
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Feb 17, 2011 | Konica Minolta X300 35mm Film Camera
There is no instruction on how to load film please help
You can download a copy of the manual from
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
The film-loading instructions begin on page 2.
Feb 11, 2011 | Vivitar V3800N Zoom 35mm SLR Camera
I got this camera and i cant load it is there a web site on how to load it?
This is hard to demonstrate or describe over the internet. The best thing for you to do is take it into a camera shop and buy a film, then get the guy to show you how to load it. You are going to have to buy film anyway.
Nov 03, 2010 | Ricoh XR-7M II 35mm SLR Camera
I have a NikonN70, how do i unload the film?
Slide the camera back lock release down, open the back, and pull out the film cartridge. Full instructions are in the manual. "LOADING FILM" is on page 16, "REWINDING FILM" is on page 24, and page 25 shows how to remove the film.
http://butkus.org/chinon/nikon/nikon_n70/nikon_n70.htm
Oct 05, 2010 | Nikon N70 35mm SLR Camera
How do i load up my film?
Turn on the main switch, then open the camera back and insert the film. Pull film leader out to the red index mark. Gently close the camera back until the lock release snaps closed. Film automatically advances to the first frame.
For full details, including illustrations, refer to the manual. If you don't have one, you can download it from
http://butkus.org/chinon/nikon/nikon_n60/nikon_n60.htm
Aug 16, 2010 | Nikon N60 35mm SLR Camera
HOW TO GET STARTED WITH NIKON N65, I DO NOT HAVE A MANUAL. HELP PLEASE.......TNX.
Basically, you insert batteries, load film, attach a lens, point the camera, and press the shutter release button :-)
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 11, 2010 | Nikon N65 35mm SLR Camera
Can't load the film
Turn the camera on. Open the back. Insert film, pull it across to the red mark. Close the back.
Camera should load automatically.
You can get the manual at http://www.butkus.org/chinon/nikon.htm
May 22, 2009 | Nikon N75 35mm SLR Camera
Photography Logo
63 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
