Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Smoke after cancelling drying cycle
Hi all, I've just cancelled a drying cycle after about 2 minutes then when I opened the door, a small amount of smoke came out of the drum. Is this just some moisture on the heating elements or could it be something more serious? Any advice is greatly appreciated. Cheers Duncan
  • hotwash Sep 04, 2007
    thanks a alot. I tried the machine on a wash and then another dry cycle and it seems so be working fine - thanks for putting my mind at rest though!
  • 183 Answers
This is due to the condener working on the dryer, it is perfectly normal however you should not open without putting through cooling off stage otherwise you may cause damage to the machine.
Posted on Sep 01, 2007
Were there recalls on any of ghese models
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Apr 19, 2014 | Maytag Neptune Washing Machines
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Clean light is flashing
As an example on a kitchenaid dishwasher when the clean light flashes 7 times this is a control error that be corrected you would press Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and press cancel. If your unit were a whirlpool dishwasher you can press hi temp heated dry hi temp heated dry with the door open which does end up lighting all the led's and when you shut the door makes the unit cycle into the wash stage. after you hear the unit letting water into it listen for the wash cycle to start and then press cancel. After the unit drains then you can set your unit to wash again. I will await your reply as to what type of unit you have before continueing on with a exact solution for your unit. Thanks
Oct 08, 2011 | Dishwashers
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
My clean light is blinking and it will not start
Push in this order within 5 seconds...
Sani Rinse Air Dry Sani Rinse Air Dry....if you dont have those buttons, substitute:
Hi Temp Wash Heated Dry Hi Temp Wash Heated Dry
Let it go through the diagnostics cycle, about 10 minutes. Push Cancel/Drain. If it occurs again, you have something wrong with the heater circuit. Check the heating element for breaks.
Jan 13, 2011 | Kenmore Dishwashers
Blinking clean light, will drain with cancel button,wont wash
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
65 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
