Question about SATO Office Equipment & Supplies
Excel printing problem - SATO Office Equipment & Supplies
Canon pixma mp287
Are you sure the correct printer is selected in Excel? I would compare Excel print settings with Word settings, since Word is printing docs.
Dec 08, 2013 | Office Equipment & Supplies
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
Jul 18, 2011 | Office Equipment & Supplies
Since upgrading to Windows 7, I can't print from Excel (Office 2003). When I try, a "Print to File" window pops up even though that check box is unchecked in the print window. I can print from Word and...
try to make the installed printers as a default printer and then try to print.
in case that does not work when you try to print from excel, click on the drop down for printer name and select the correct printer.
This should help you
Jul 12, 2010 | Microsoft Excel for PC
When I print from excel the page comes out blank
ok... here are some general tips... in your print driver make sure that it is set to spool documents... it gathers everything and then prints... make sure the print driver isn't shared from a server... servers are famous for distorting excel printer communication.... it isn't the konica... its a print driver excel conflict...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 11, 2010 | Konica Minolta bizhub C250 All-In-One...
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
I have several address stored in Excel. Now I
You don't need to print labels in Excel. You can use the mail merge feature in Word to do so. Use the Excel file as the data.
Nov 06, 2009 | Microsoft Excel for PC
When i print a PDFdocument made as an excel sheet , i mean with chart ,all that's writed inside is not printed. On Printed sheet you can just see an empty schedule. thanks
Why not convert the PDF to Excel and then print the Excel Spreadsheet? Nearly everybody know how to use excel and print the contents.
You can try AnyBizSoft PDF to Excel Converter which can help you transfer the tables of PDF into Excel as the original format. All the charts and data will be preserved.
Have a try and hope it helps.
Jul 19, 2009 | HP Photosmart C5280 InkJet Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
Using Job Accounting with Excel
Try unticking the collate box on the print window. this can cause 50 jobs to be sent rather than 50 copies of the same job.
Hope this helps
Mar 27, 2007 | Canon ImageRUNNER 3570 Copier/Printer
22 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
