Question about Saeco Odea Go
Boiler doesn't warm up
After a thunder my Saeco Odea Go doesn't warm up; the light "!" always blinking.I have check the value of resistance on boiler and I have measured 100ohm, I don't know if this value it's correct but isn't interrupted and isn't shortcut.I have check the thermostate and the fuse all are ok. I have check the ntc sensor inside the boiler and it's ok. So I thought that the problem could be the triac, so I have changed the triac component Q8012LH5TP - TRIAC, 800V, 12A, but still doesn't work. I'm not sure if the problem is only on electronics mother board or there are other problems. I want to be sure that the problem is the electronic mother board because cost it 50-90euro. Could you help me?
Change the heater
Posted on Mar 26, 2017
5 Suggested Answers
JohnnyBeans
  • 223 Answers
SOURCE: No warming
The Brew Boiler Temperature is 192 Celcius
http://cerinicoffee.com/Thermofuse_192.asp
Posted on Dec 14, 2007
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
EsWorld
  • 1618 Answers
SOURCE: My Saeco Spidem Villa has just stopped working.
Have you checked the power button to make sure it is not defective, if yes then check the capacitor under the pump to make sure it is not damaged.
Posted on Jun 30, 2009
SOURCE: Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Posted on Oct 16, 2009
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
Jun 26, 2010 | Saeco Odea Go
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
Saeco Odea Giro : Water tank problem
The only thing I can think of is the reed switch on the back of the panel that checks the water level. If there is a float in the water tank check what level it is when it calls for refill, it might be in backwards, or the magnet has moved.
Mar 04, 2010 | Saeco Odea Giro Plus Coffee Maker
My apparatus SAECO ODEA GIRO doesn't light on anymore Thanks for your help
Thermal switch has tripped on the boiler and can be reset by pushing in the pin. Or more seriously can be the circuit board failure.
Jan 09, 2010 | Saeco Odea Giro Plus Coffee Maker
Green indicator keeps on blinking
It is exactly like btmachi says, the thermostat needs resetting. I have done it myself and have made a walkthrough as to how to do it. Find it here: http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Hope it helps
Jan 08, 2010 | Saeco Odea Go
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
88 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
