Question about Exercise & Fitness
The fuse on my treadmill went so I changed it with a new fuse, but now the treadmill doesn't turn on at all!! Help?
    Top Expert:
  • 12,223 Answers
PLEASE see the video and fix it. God bless you
Posted on Jul 15, 2013
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have an athletech performance treadmill it won't turn on on button doesn't click as does the off button
Dear Sir:
1) Try to reset the c. breaker in your treadmill.
2) Inspect if your see some loose wires.
3) Open the keypanel and tight the flexible cord or ribbon cables.
4) Tight the connector coming from display planer to lower boar or main motor board.
5)Test the Transformer for there are voltage in primary and secondary winding.
6) Measure the input to the power board
7)See there are +5VDC to the main motor board and display board?
8) Run the calibration Software read your user manual or see under the Hood the motor the instruction for more easy diagnose and troubleshooting . Attached is my block diagram that I did design for purpose of diagnose. sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 16, 2012
ercupa190
  • 12223 Answers
SOURCE: treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Posted on Jun 03, 2012
ercupa190
  • 12223 Answers
SOURCE: My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Posted on Jul 20, 2012
ercupa190
  • 12223 Answers
SOURCE: my treadmill turns on, but doesn't start
1) LUBE the deck belt, this happen by lack of maintenance, maybe you have deck worn.
2) LUBE the rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Jul 24, 2012
How to fix treadmills JKEXER vigor 6090 broke down with smoke and fire ?
sounds like motor went bad tripped the breaker ! go to fuse box look for breaker that's not all the way on turn it off then back on that will get your power back on make sure you un plug treadmill
Sep 06, 2014 | Exercise & Fitness
My carl lewis mot566 doesn't have power even though it is plugged into the mains
please see the video and test it. God bless you
However you must use the desk lamp in outlet wall, if the lamp DOES NOT turn ON the problem is the outlet, reset the c.breaker and test the wiring:white+black+green with DVOM for open, short circuit, and bad contacts and repair.
Jan 08, 2013 | Exercise & Fitness
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 15, 2012 | Exercise & Fitness
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
Belt starting slipping, adjusted according to User's manual...belt still slips.
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt.
If then also the belt is slipping then you have to replace the running belt with a new one.
ok
Sep 03, 2011 | Reebok T 1280 Treadmill
My treadmill will not turn on at all. I ran the day before and then all the sudden it doesn't work?
A few things to check... Plugged in? Power switch on? Fuse ok? Safety clip in?
Jun 09, 2011 | Ironman Exercise & Fitness
Everything works. but the treadmill motor won't start when I press the on button.
If you press start and the belt will not turn, but your incline is working, the time is counting and the speed #'s change. The problem would most likely be the lower control board. It could also be your motor. Have a professional test the motor with a DC voltage source. If it tests OK the problem is almost certainly the control board. Depending on the brand, some control boards have a fuse. Have the fuse checked and if it is bad replace it and try starting the treadmill again before you buy a new control board.
Nov 23, 2010 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
161 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
