Question about Kenwood eXcelon KDC-X559 CD Player
Power, and system beeps, but no music
I power up my head unit and no music comes forth, it has power, no error coded, cd player reads, and the system still beeps when changing source, menus ect. Opened it up, nothing looks burnt, or unhooked. What happened... was working well, hit a bump, got static then nothing, so i figure something maybe toasted will keep digging deeper, any advice on where to start?, what to look for? would love to get back up and running. Joe
I have problem with CD player.
The drive tries to read the CD but fails, then "resets" to try again. It is likely the complete unit will have to be replaced even though the other functions work.
May 04, 2014 | Panasonic Car Audio & Video
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
We have Marantz PMD 325 CD players. Usually TOC REading comes up when you put a CD into the player. However sometimes we now get the following message "PMA Reading", What does this mean.
Hi Wendy CD-Rs and CD-RWs have a component that ordinary music CDs do not have -- an ...This additional track space includes the power memory area (PMA) and the ... which tells the CD player what part of the disc it is reading at any particular time. ...uncorrected error on a music CD only means a bit of fuzz or a skipping noise. GOOD LUCK !
Jan 05, 2014 | Marantz SA8260 CD Player
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
7 beeps will not come on
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 13, 2012 | Dell Computers & Internet
Radio works fine. cd player wont read discs in either of four slots. Message - Disc error.
This can often be solved by opening the cover and blowing on the optical head to displace dust and any debris that is fouling between the optics and the actuator that controls the head position. It isn't fool proof but will fix perhaps 40% of units. Take a can of air duster (aerosol blower) and blow the little pick-up form the distance of about 1 inch. It will bounce around in the wind but don't blow to hard. Give it a gentle blast and then try the player. If it doesn't work then try again this time but blow harder.
Feb 27, 2012 | Bose Wave Music System CD Shelf System
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
My pioneer head unit wont come off mute when i turn on the radio mp3 or cd player
It happened to me today and it passed after a while when i was arriving home. Try to reset it by taking the power source off for a couple of minutes then try again.
Don't forget about your system definitions, it will be restored to default.
May 21, 2010 | Pioneer DEH-P5900IB CD Player
Region code for DVD player
If you want to know whether the region coding can be hacked on your unit then you need to state both the make AND model. If it's reading DVD's but not CD's then the reading head is faulty and must be replaced, but it's rarely an economically viable repair.
May 19, 2010 | Audio Players & Recorders
Player skip reading the music then come back to start over
Pull the top off the unit and use a can of Dust Off (compressed air) and clean out the inside. Then use a Laser lens cleaner and run it thru the unit once or twice. This is considered normal maintenance on a 300 or 400 disc changer that should be done annually. If it still won't play a disc, replace the unit, the replacement model is around $ 199.00. A repair would easily cost that much. Hope this helps.
Apr 11, 2010 | Sony CDP-CX300 CD Player
Kenwood eXcelon KDC-X559 CD Player Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
