Question about Watches
Just changed the battery in my Adidas ADP1426, now the screen just displays "230" and none of the buttons do anything....? What do I need to do to get it back up and running?
  • Watches Master
  • 18,394 Answers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Posted on Jul 15, 2013
Set time on adidas Adults' Performance Duramo Watch
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Mar 15, 2012 | Adidas Watches
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Jan 07, 2011 | Adidas ADH1572 Watch
I CAN CHANGE TIME AT MY ADIDAS ADH2045. HOW IT'S POSSIBLE???
hold set button(top left) in for two seconds until 'light 'displays,then press bottom left button(mode)to scroll though hours etc,(use right buttons to adjust)when finished press top left again
Jan 04, 2011 | Adidas Digi IV Watch
My adidas adp1426 watch had a new battery put in and not none of the side buttons work, the only response i get is when I hold all four down at once it resets but continues to have the same problem, any...
Thank you for contacting FixYa.<br /> Did you do the battery yourself or have a repair service center do for you??<br /> It could be that the buttons are not making the correct contact or that it needs to be reset.<br /> I would take back to service center and see it they can correct. If needed, you can also contact Adidas at :<br /> <a href="http://www.adidas.com/us/shared/help/help_contact-us.asp">http://www.adidas.com/us/shared/help/help_contact-us.asp</a>
Aug 25, 2010 | Watches
Start buttons don't work after battery change Adidas Sports Timer
You will have to open your watch, because the contacts or contact springs are not stiff enough, so, you need to make them stiffer.
Do as follows:
1) Open your watch caseback
2) Extract the movement (carefully and using tweezers), do not touch dial with fingers,
3)Take small brush and lighter fluid (ZIPPO) and clean all pushbuttons in case from inside and out pushing them rapidly, then use dust blower to dry the fluid out,
4)On the movement you will see contacts corresponding to each pushbutton on the case. Use needle or sharp metal pin to clean (scrape) off any visible residue from these contacts till they are shiny.
5)Pull all contacts on movement sligtly outwards using tweezers but be careful not to brake. This will make them stiffer.
6)Reassemble the watch and the problem should be sorted.
Do not forget to rate, please.
Aug 14, 2009 | Watches
Light button causes the time to reset, why?
Your battery is low and needs to be replaced, the light uses much more power than it takes to run the display
May 26, 2009 | Adidas Candy Digital watch
Adidas watch ADP 1112
change the battery for that... its showing errors which means that needs a new battewry.
Apr 12, 2008 | Adidas Digi III Watch
Watches Logo
43 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
