Error code 53 - VGT M/V3 on fuso 6M70 engine
Please can you tell me what this error code means
I have a problem code 53 vgt m/v3
Posted on May 09, 2018
Mike258
  • 1498 Answers
SOURCE: code 53
Hello yeremya1776,
For Jeep Grand Cherokee, 1991-95 models:
Code 53 - Internal Controller Failure - Internal engine controller fault condition detected during self test
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Posted on Aug 06, 2008
redbeard00
  • 957 Answers
SOURCE: Need error code information for 1995 Ford Aerostar minivan
Code#53: throttle position sensor high voltage. #85: canister purge failure. 36: (CSI) flow low or low revolutions per minute increase.
Posted on Jun 06, 2009
freeagain76204
  • 208 Answers
SOURCE: I just want to request a user manual for Mitsubishi Fuso Super Great (Engine Model : 6M70-T4)
auto parts store usually has them if not they should be able to order one
Posted on Nov 03, 2014
  • 50501 Answers
SOURCE: Mitsubishi Fuso Truck engine model 6M70 Intermittent opening and closing of exhaust valve.
this is an exhaust brake truck where the brake is in the exhaust manifold
the brake valve is actuated through a solenoid that controls the air pressure to the valve cylinder or the electric solenoid for the valve
it is operated either by the driver through a switch on the steering column or by a switch at the accelerator pedal where when the exhaust brake is switched on then with the accelerator pedal in the idle position it activates the actuator
there the problem will be in the switch at the base of the accelerator pedal, the switch in the dash or in the actuator itself
Posted on Sep 04, 2015
Testimonial: "thanks a lot bill for your immediate reply.do i need to undergo ECU scanning to locate where the fault coming from?I have already check the switch on the accelerator pedal and it is working properly so with the switch on the clutch pedal.Now the issue is even though i did not push the exhaust brake switch to on position at the steering column the exhaust brake opens and closes the exhaust brake valve as the engine temperature reaches around 1/4 of the temperature gauge."
  • 51484 Answers
SOURCE: fuel knock of 6m70 fuso engine on low rpm low power,hard start
and why was water introduced into the system . they will not run on water EVER
Posted on Feb 15, 2016
WHAT is ECU in fuso super great 6m70
The ecu is the computer for the engine.
Sep 19, 2017 | Cars & Trucks
Fuel knock of 6m70 fuso engine on low rpm low power,hard start
Feb 15, 2016 | Cars & Trucks
Please help me regarding my problem 6m70 fuso that
Very confusing question. No idea what you are asking. Sorry
Dec 02, 2014 | Cars & Trucks
What is the problem of my fuso super great 6m70 engine..when you rev to 20k rpm it will changed the engine timing or "palyado" when it switch off then start again it back to normal again..pls help me..TIA
All computer controlled ignition systems are set to a base ignition timing. The computer will advance or retart the ignition timing according to engine speed and load. This is normal.
Nov 20, 2014 | Cars & Trucks
Nov 03, 2014 | Cars & Trucks
81 people viewed this question
k24674
jasbo
jasbo
