Hello, My siemens siwamat xl 540 stops in millde of the program and I need to press start again (sometimes over and over again). Do you have any idea what causes it and what I can do about it?
SOURCE: Drum spins once and stops
Hi there i recondition hundreds of these machines a year and i can tell you that your problem is the module board which has short circuited due to a wiring problem or depending on the type of motor that was fitted. you looking at a lot of money there is no easy fix to this problem.
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
SOURCE: Using of Siemens Siwamat
press the start button after the door is closed.
if it does not start - the door switch/latch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
