Question about Baby Gear
Easywalker Duo foam handle needs replacing, where can I get one and how do I change it? Thank you.
SOURCE: Graco Duo Glide 7443
we missing one part,when you folder the stroller they have little red snap for loked
Posted on Aug 22, 2008
  • 3 Answers
SOURCE: torn foam covering on handle
Hi there's a place in america that sells replacement zip up foam covers for the Quinnys, do it in various lengths so you can also get one for your bumper bar at the front if thats a bit tatty as well. They are about £20 including shipping which is fairly reasonable considering how much the cost in the first place! Go onto ebay and look for 'quinny handle cover', and there's also companies on ebay that do replacement quinny stickers as well for a few quid as they wear so quickly.
Posted on Feb 09, 2009
  • 127 Answers
SOURCE: Buzz 2006 cracked foam on handle...replacement part?
Call your local bike store they might be able to fix it.
Posted on May 29, 2009
SOURCE: spilt foam handle
i'm looking to find replacement foam for the handles on a chicco ergos buggy and also a new reclining bar for the left. help pls
Posted on Mar 08, 2010
  • 223 Answers
SOURCE: the handle foam needs replacemant
Hi you can get it replaced at any bike shop
Posted on Aug 07, 2010
How to fit the foam handles onto the liteway buggie
I tried to remove rivets, no luck. I used WD40 to lubricate replacement foam and slipped it over the big plastic caps. Hard to start but worked well, foam did not tear, all fixed.
Feb 21, 2013 | Chicco Liteway Stroller by
My Dolphine 2002 works but has water inside the handle that seems to make if difficult to climb walls. Can the water be drained some how and the handle resealed?
Thank you for posting your question here on Fixya.com.
Purchase a can of spray foam insulation and then drill a hole in each end of the handle to match the spray tube on the insulation. Let the handle dry once the holes are drilled then fill the handle with the foam from one end until it begins to expand out of the holes. Once the foam has set you can trim off the excess and scoop out a dimple of foam from each of the holes. Seal the holes with a two-part epoxy but even if the handle still leaks the foam will prevent much water from getting in and the handle will remain buoyant.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jul 25, 2011 | Dolphin Maytronics Advantage
My Bugaboo Frog has a split in the foam on the handlebar. Can this foam be replaced, if so where can I get it in the UK. Thanks, Jane.
The foam is a product called neoprene tubing and can be found at specialist rubber product suppliers. Google a local supplier. Changing the grab bar rubber is easy just use hot soapy water but the handle bar is a problem as the foam is fitted before assembly and it would require disassembly to replace. This is not easy as the handle is riveted on and has internal parts to operate the handle locks. You can buy a special glue for repairing wetsuits to fix the split and stop it opening up further.
Nov 13, 2010 | Bugaboo Cameleon Jogger
How to change foam on handles
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website.
And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
http://www.ehow.com/how_6730072_change-bike-grips.
html Bike grips and stroller handles work the same way.
I just used this post on e-how to replace my maclaren triumph foam handles.
Works like a charm - and it's sooo easy!! :)
Sep 26, 2010 | Bugaboo Cameleon - Tailored Fabric...
The handle foam needs replacemant
Jul 08, 2010 | Quinny Freestyle 4 Marina Stroller
Spilt foam handle
Jun 01, 2009 | Chicco London Stroller Umbrella
Need a replacement foam bit for handle, where can I get one
I have bought a new foam part for the handle on my Phil and Ted e3 stroller, but how do I change it? Has anyone done this successfully? Any tips?
Apr 08, 2009 | Maclaren Twin Techno Storm Umbrella...
Aug 21, 2008 | Graco Baby Gear
Baby Gear Logo
49 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
