Ge air conditioner 8000 btu manual
Water spraying out of the fan
    New Friend:
    Problem Solver:
  • 13 Answers
Your unit is purely short of gas
Posted on Jul 15, 2013
SOURCE: Window unit air conditioner leaking water inside home
Hi, I had the same problem see http://homefixfree.com/index.html
they were the big help!
Posted on Apr 14, 2008
SOURCE: windchaser 10000 btu air conditioner
blowing good but not cooling
Posted on May 01, 2008
bobotfel
  • 236 Answers
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Posted on Jun 10, 2008
  • 340 Answers
SOURCE: my 8000 btu a/c is spraying water out the front and making loud n
It needs to be taken apart and cleaned.Tom
Posted on Jun 20, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
NEED HELP TO REPLACE WIRES ON CAPACITOR ON GE ROOM AIR CONDITIONER 8000 BTU
with capacitors it doesn't matter which wire goes on which terminal
if it has just 2 terminals then a wire on each
if it has 4 terminals then one wire on one set and the other wire on the other set
A set is two terminals side by side
However if you are still undecided , get an electrician to fit the wires.
May 09, 2015 | General Electric GE AEM08LQ 8000 BTU...
My portable ge air contioner 8000 btu keeps blowing fuses, even when it is the only thing plugged into that fuse
The reason you are blowing fuses is 'high amp draw,' which is most always caused by a 'electrical short,' and the most common things to cause such a short are the 'compressor and fan motor(s).
I would say you need a serviceperson to determine exactly what is causing your short.
Jun 09, 2011 | GE APN08AA Portable Room Air Conditioner
New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Aug 19, 2009 | LG Electronic Window Air Conditioner
GE Air conditioner cannot kick into airconditioning mode
it sounds like either the start components for the compressor have failed or the compressor itself has failed, since it is not kicking the breaker I would lean towards start components.if it is a PSC only comprssor, you may be able to add a start assist to get the compressor started. I assume that since it is 8000 btu it is 110VAC you can probably get a generic start kit at your local appliance parts house. they have a diagram and are fairly easy to install, just be aware that the capacitor storea charge on the OFF cycle, and can be dangerous
Jul 19, 2009 | Heating & Cooling
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
My GE portable air conditioner is not cooling but fan works
I think it's becuase the water tank on the side is full and when that happens it turns off. Empty the water...and then reach your hand in and find a small reset button press it and then but the chamber back in and see if that works. I had that problem and same code
May 25, 2009 | GE APN08AA Portable Room Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
