Question about Toshiba e-Studio163 Copier
E Studio163 - Printing - "No cassette with paper of size requested is available"
Hey I am trying to connect the e studio 163 to a window Xp pc. I have instaled the USB driver and then connect it to the com port in add printer. I am now getting the above error. Any ideas why? HOw do I get the e studio to print for me Thanks Ger
After changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
any ideas why?
machine:e studio0259
Posted on May 04, 2008
  • 838 Answers
First I will ask you all to install the printer driver or if you have the CD install the Toshiba Viewer Software as well then you can use that as an scanner also.....connect the printer to pc...then go to printer properties>device setting >Form to Tray assignment>change all the options to A4...>apply>OK.....Good Luck
Posted on Jul 22, 2009
Check the paper size in the printer's properties, the tray 1 is A4 for default, be sure to change Letter
Posted on Oct 01, 2007
    New Friend:
If u tryed everithing then go to properties/custom properties/(paper/quality)/ then select BYPASS CASSETTE.
it helped for me, bye have a nice day and good luck :)
Posted on Nov 30, 2015
I want printer driver
Posted on Nov 04, 2008
Hardware issue this problem from,Muhammad Hamid
    Problem Solver:
  • 18 Answers
Try reseating the paper trays and clean any sensors the tray might have or the printer to tell it there is paper there or that the paper tray is in. make sure you program the paper into the machine so it will know the paper type.
Posted on Aug 29, 2007
SCAN
Install the viewer software that use for scanning
Jun 13, 2017 | Toshiba e-Studio 205 Copier
Cannot load drivers for printing toshiba e-studio 167
if connect to usb cable, then u need to install usb driver b4 installing printer driver
May 26, 2011 | Toshiba E-Studio167 Copier
How do i use Toshiba e Studio 163 Copier as a Scanner ?
how can i use Toshiba E studio 163 as a scanner?
can print.. But can't Scan Anything even can't see the scanning opition or even icon..
Sep 29, 2010 | Toshiba e-Studio163 Copier
How can I share my HP officejet 5610 all in one printer that is connected to my desktop that has windows XP with my windows vista laptop?
1. Unplug your USB cable from the back of the Windows XP PC and plug the USB cable directly into your Windows Vista PC.
2. The Windows Vista drivers for your printer should be automatically loaded and your printer will be installed on your Windows Vista PC. If this was successful, skip right to step 3.
If step 2 is not successful
i. Download the Windows Vista printer driver for your printer from
the manufacturers website.
1. If your printers manufacturer has not created a Vista driver
yet, retry step 2.
ii. Install the driver on your Windows Vista PC. During
installation, youll be prompted to connect the printer to your PC.
Choose the option to proceed with installation without connecting the printer.
3. After installation is complete, open the Printers icon in the Windows Vista Control Panel.
4. Right-click on your printer that was just installed and choose Properties.
5. Navigate to the Ports tab.
6. Click Add Port, then select Local Port, then click New Port.
7. For the Port Name, enter the exact network path and share name of your printer. (ex. - \\HOMEPC\Printer2) 8. Click OK and make sure that this new port is selected with a check in the checkbox.
9. Click Apply and then OK to close the printer properties.
10. You should now be able to print from your Windows Vista PC to a shared printer located on your Windows XP PC.
Jun 17, 2010 | HP Officejet 5610 All-In-One InkJet...
I want driver for windows 7
It seems that Toshiba's latest driver for this device supports only Windows XP and Vista 32-bit.
Here are the links:
1. Scan/Print Driver, Win 2000/XP v2.30
2. Scan/Print Driver for Vista 32 bit
3. Button Manager for Vista 32 bit
Manufacturers usually drop support for older devices after some time. Specially for printers and scanners the support is even more limited; most of them (if not all of them) offer warranty of one year.
Your best shot is to try the Vista drivers. For printing you shouldn't have problems. When you install the printer Windows have generic drivers for supported (current/older) devices. This driver should work for printing.
For scanning you can try something like VueScan which is compatible with Windows 7. Toshiba devices are not in their list of compatible scanners, but you can never know...
Note that VueScan only works with SCSI, USB and Firewire connections, most wireless Canon and HP scanners (on Windows and Mac OS X only) and doesn't work with parallel-port connections.
This can be solved with a parallel to USB cable converter (be sure to check whether you need male or female parallel to male or female USB converter).
I hope this answers your request.
Nakis
Feb 16, 2010 | Toshiba e-STUDIO 120 Laser Printer
How to use e studio 163 on windows 2008 os
How u connect your MFP, via USB or network?
If USB, viewer 2 is not supported on window 7 & 2008. If networking, u can try the minidriver.
Jan 08, 2010 | Toshiba e-Studio163 Copier
E-studio 163 coppier - I cannot connect it to pc
hi frnd do one thing
go to printers and faxes
select toshiba e-163,
right click
select properties
select port
select com 3
try to give print
OR
select com 4
and give print i may be ok.
pls up date me
regards
san
Aug 17, 2008 | Toshiba e-Studio163 Copier
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Toshiba e studio 163 drivers for XP
Try looking here:
http://www.eid.toshiba.com.au/
You need to know if it uses the GDI print system or the optional print board.
Browse the driver section and you should get there.
Nov 12, 2007 | Toshiba e-Studio163 Copier
Toshiba e-Studio163 Copier Logo
4,064 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
